Introduction to creating maps for IPS
Available for an ArcGIS organization licensed with the ArcGIS IPS extension.
ArcGIS IPS requires a map that is IPS-aware to enable indoor positioning. To make a map that is IPS-aware, you must first create an indoor positioning dataset using the survey-less method (suitable for Bluetooth IPS only) or the classic survey-based method. Depending on the method you choose, you will need to collect different types of data using the IPS Setup app.
Learn more about creating the ArcGIS IPS Information Model and creating and sharing a map for use in IPS Setup.
