Share an indoor positioning data service
Available with Standard or Advanced license.
The indoor positioning data service is a feature service that contains radio signal and, optionally, geometry data unique to a specific indoor environment and optimized for live indoor positioning in that environment. Use the Share Indoor Positioning Data Service tool and an IPS positioning dataset to publish an indoor positioning data service. Once you publish the indoor positioning data service, you can enable IPS awareness in maps and web maps and indoor navigation in IPS-compatible apps, such as Indoors Viewer.
To create and share an indoor positioning data service to the active portal, complete the following steps:
  1. Start ArcGIS Pro.
  2. On the ribbon, click the Analysis tab and click Tools .
    The Geoprocessing pane appears.
  3. In the Geoprocessing pane, click the Toolboxes tab.
  4. Expand the Indoor Positioning Tools toolbox and click Share Indoor Positioning Data Service.
    The Share Indoor Positioning Data Service tool opens in the Geoprocessing pane.
  5. Click the Browse button next to the IPS Positioning Datasets parameter and choose a feature class that contains the dataset you want to share.
    The Dataset Name drop-down list is populated with the names of the datasets available in the selected feature class.
  6. Click the Dataset Name drop-down arrow and select the dataset that you want to share.
    Verify the ArcGIS IPS coverage of the indoor positioning dataset before sharing the indoor positioning data service.
  7. Specify the Target Version of the indoor positioning data service to be shared.
    • Version 1—Stores positioning data as tables and feature layers. Version 1 is the only valid option for IPS positioning datasets that use the Connectivity Graph geometry format. It is also compatible with non-geometry-aided datasets. Services shared as Version 1 are compatible with mobile apps built with earlier and later releases of ArcGIS Maps SDKs.
    • Version 2—Stores positioning data in a binary-encoded format. Version 2 is the only valid option for IPS positioning datasets that use the Classification Grid geometry format. It is also compatible with non-geometry-aided datasets. Services shared as Version 2 require mobile apps built with ArcGIS Maps SDKs 300.2 or later.
  8. Optionally, provide a different name for the indoor positioning data service in the Title text box.
    The Title parameter is automatically populated with the dataset name by default.
  9. Optionally, provide values for the Summary and Tags parameters.
  10. Optionally, click the Folder drop-down arrow and select a folder in the organization content where the indoor positioning data service will be shared.
    The service is stored at the root level of the organization content by default.
  11. Click the Sharing Level drop-down arrow and specify how the indoor positioning data service will be shared:
    • Everyone (public)—Share your content with the public. Anyone who has access to the portal can find and use it.
    • My Organization—Share your content with all authenticated users in your organization.
    • Groups—Share your content with groups to which you belong, and their members.
    If you leave all options unchecked, the indoor positioning data service will only be available to you (private).
  12. Click Run.
An indoor positioning data service is published to your ArcGIS organization and can be used to enable IPS awareness in maps and web maps.
