Split an event
Available with the Linear Referencing license.
Use the Split Event tool to split a line event into two adjoining events. You can edit the attributes of the event after you click the location to split. After the tool runs, the input event is retired and the resulting split events receive new event IDs.
Before using this tool to edit a feature service, you must share branch versioned linear referencing system (LRS) data as a web layer. If the feature service is not yet published, see Share as web layers.
The example in the following workflow demonstrates splitting a spanning event at measure 20 on Route 2 using the Split Event tool .
The following diagram shows the routes and the event:
Splitting a line event
The following workflow details splitting an event at measure 10 on Route 1 using the Split Event tool .
The following diagram shows the route and the event:
The following table provides details about the event before the split:
Event Engineering Route Name Engineering To Route Name From Date To Date Engineering From Measure Engineering To Measure Location Error DOT Class
Event1 Route1 Route3 1/1/2000 <Null> 5 35 No Error Class 1
Event Route ID From Date To Date From Measure To Measure Location Error Lane Width
Event1 10100000123000001 1/1/2000 <Null> 0 20 No Error 7
To split a line event, complete the following steps:
  1. Start ArcGIS Pro and open a project with LRS data in the map.
  2. Zoom to the location where you want to split a line event.
  3. On the Linear Referencing tab, in the Event Editing group, click Split .
    The Split Event pane appears.
    Split Event pane
    Split Event pane
  4. Click the Event Layer drop-down list and choose the event layer that contains the event you want to split.
    All of the line event layers in the feature service appear in the Event Layer drop-down list. The fields and values in the Event1 Attributes and Event2 Attributes parameters update when the event layer changes.
  5. Specify a route by doing one of the following:
    • Click Choose route from map and click a location along a route where you want to split the line event.
    • Provide a route name in the Route Name text box.
    • Provide a route ID in the Route ID text box.
    If multiple routes exist at the edit location, select one of the routes in the Select a Route dialog box.
    If you used the Choose route from map button to click a route, the Route Name, Measure, and EventOID parameters are populated in the Split Event pane, and a green point appears on the map at the clicked location.
    If you used the Choose route from map button to click a route, the Route ID, Measure, and EventOID parameters are populated in the Split Event pane, and a green point appears on the map at the clicked location.
    Tip:
    • After clicking Choose route from map , you can hover over the routes to see the route and measure at the location of the pointer. You can set map scale options for display of route and measure information in the Linear Referencing options.
    • When hovering near a feature, you can turn snapping on to improve the accuracy of the pointer.
    If a message regarding acquiring locks or reconciling appears, it means that conflict prevention is enabled. After you select a route, the tool attempts to release the route lock if the active user acquires the route lock in a different named version and the releasable status value is Yes.
  6. If you manually provided a route name in the Route Name text box in step 5, enter a value in the Measure text box.
    The object ID of the selected event appears in the EventOID parameter.
    A green point appears on the map at the measure location. The event splits into two events on either side of the green point.
  7. If you manually provided a route ID in the Route ID text box in step 5, enter a value in the Measure text box.
    A green point appears on the map at that measure location. The event splits into two events on either side of the green point.
  8. Optionally, change the start date of the event being split by doing one of the following:
    • Provide the start date in the Start Date text box.
    • Click Calendar and choose the start date.
    • Check the Route start date check box.
    The default start date is the current date.
  9. Optionally, specify the end date of the event being split by doing one of the following:
    • Provide the end date in the End Date text box.
    • Click Calendar and choose the end date.
    • Check the Route end date check box.
    • Double-click in the End Date text box to use the current date.
    If you do not provide an end date, the event remains valid from the start date into the future.
  10. Optionally, edit the attribute values in the Event1 Attributes and Event2 Attributes parameters.
  11. Click Run.
A confirmation message appears once the split is complete.
The following table provides details about the events after the split is complete. Event 1 has a start measure of 5 on Route 1 and an end measure of 20 on Route 2, while Event 2 has a start measure of 20 on Route 2 and an end measure of 35 on Route 3.
Event1 Route1 Route2 1/1/2000 <Null> 5 20 No Error Class 1
Event2 Route2 Route3 1/1/2000 <Null> 20 35 No Error Class 2
The following table details the event after the split is complete. The end measure of Event 1 changes from 20 to 10, and a new event, Event 2, is created from measure 10 to measure 20 on Route 1 with a different lane width.
Event1 10100000123000001 1/1/2000 <Null> 0 10 No Error 7
Event2 10100000123000001 1/1/2000 <Null> 10 20 No Error 6
The following diagram shows the routes and the associated events after the split:
After splitting a line event using the Split Event tool
