Reading netCDF data as a table view
Using the Make NetCDF Table View tool from the Multidimension Tools toolbox, you can create a table view from one or more netCDF variables. The output table view can be used in other tools that accept tables as input for further analysis. To save the table view, click the Option button and choose Export in the table or use the Copy Rows or Export Table tool.
You cannot add a netCDF table view using the Add Data button .
A table view can be created using any variable with at least one dimension. The fields in the table view are populated with the data from the selected variables. The type of the field is determined based on the netCDF data type. The following example shows a variable with one or more dimensions.
dimensions:
    station = 10; // measurement locations
    pressure = 11;
    time = UNLIMITED;
variables:
    float humidity(time, pressure, station);
        humidity:long_name = "Specific humidity" ;
        humidity:coordinates = "lat lon" ;
    float temperature(time, pressure, station);
        temperature:long_name = "Temperature" ;
        temperature:coordinates = "lat lon" ;
    double time(time);
        time:long_name = "time of measurement" ;
        time:units = "days since 1970-01-01 00:00:00" ;
    float lon(station);
        lon:long_name = "station longitude";
        lon:units = "degrees_east";
    float lat(station);
        lat:long_name = "station latitude" ;
        lat:units = "degrees_north" ;
    float pressure(pressure);
        pressure:long_name = "pressure" ;
        pressure:units = "hPa" ;
  1. Click the Analysis tab.
  2. Click Tools.
  3. Type Make NetCDF Table View in the text box.
  4. Click Make NetCDF Table View in the returned list to open the tool.
  5. Type the name in the Input netCDF File, or alternatively, click the browse button to navigate to the input file.
  6. Click the Variables drop-down arrow, check one or more variables from the list, and click Add.
    The variables added must share at least one dimension.
  7. Type the name in the Output Table View, or alternatively, leave the default.
  8. Click the Row Dimensions drop-down arrow, check one or more dimensions from the list, then click Add.
  9. To specify a slice other than the default of multidimensional data, click the Dimension Values drop-down arrow, check one or more dimensions from the list, then click Add. For each dimension added, click the Value drop-down list next to the added dimension and choose a value.
  10. Click Run.
    An in-memory table view is created. A table view is not visible in Catalog, but it can be used as input to other geoprocessing tools in the session in which you are working. Once you exit the application, the tables in memory are removed.
