Work with containment edit mode
Certain devices, wires, and conductors are placed inside objects such as substations, switch gears, trenches, and ducts. The relationship of a feature located in another feature is called a containment association. The feature containing other features is the container, and the features inside the container are content.
There are multiple ways to create and manage containment associations between network features including the following:
  • The Modify command opens the Modify Associations pane. You can use this pane to create and manage containment associations between existing network features.
  • The Enter Containment command is used to enter containment edit mode. When editing, this automatically creates the containment association for content features placed in an existing container.
  • Use Python scripting with the AddContainmentAssociation function to create a connectivity association.
Associations group on the Utility Network tab
Containment edit mode is useful to create content features in an existing container feature in a single step. In this mode, created features are automatically added to the active container as content using a containment association.
Content features created in containment edit mode have their visible property set to false. This means they will not be visible in the map when you exit containment edit mode.
Tip:
To show or hide containment association content on the map, you can use the Display Content command . The Display Content command is dependent on having a display filter properly configured on the Association status attribute to work. See Control association visibility for more information.
Requirements
The following are requirements for creating a containment association:
Enter containment edit mode
To enter containment edit mode, complete the following steps:
  1. Click the Utility Network tab.
  2. In the Association group, click Enter Containment .
  3. Select a single container feature in the active map.
    The asset group and asset type of the network feature being selected as the container must be assigned the containment association role and supported by network rules for containment.
    The following occur:
    • A pop-up appears indicating containment edit mode is turned on.
    • A dashed, light blue polygon appears around the selected container in the map.
    • The map zooms to the feature's extent or the view scale set on the container feature. This is controlled by the association role assignment.
Any features created in containment edit mode (with a supporting rule) become content to the container. Any deleted features are removed from the container and deleted from the network.
Exit containment edit mode
To exit containment edit mode, complete the following steps:
  2. In the Association group, click Exit Containment .
    • A pop-up appears indicating containment edit mode is turned off.
    • The dashed, light blue polygon around the container disappears from the map.
    • The map returns to the view scale set prior to entering containment mode.
Any features created while containment edit mode was on are not visible in the map. To change this, modify the visible property for the containment association content in the Modify Associations pane.
