SubnetLine feature class
The SubnetLine feature class stores a set of linear features, each representing a subnetwork. The purpose of the SubnetLine feature class is to aid visualization during editing, enable generation of subnetwork maps, and output summary information about the subnetworks.
The SubnetLine feature class is a read-only, system-provided feature class that is updated internally by the running of certain utility network tools. All valid connected lines are aggregated to comprise a single feature for the subnetwork in the SubnetLine class. The lines aggregated to create the SubnetLine feature class are specified in the subnetwork definition for the tier using the Aggregated Lines for SubnetLine Feature Class parameter. These aggregated lines are a subset of the Valid Lines values defined for the tier. Since associations are not represented in the SubnetLine feature class, a subnetwork can be represented as multipart.
The SubnetLine feature class is updated by the following:
The
Tier nameattribute field is defined as the subtype field for theSubnetLinefeature class. For each tier that is added to a domain network using the Add Tier tool, an additional subtype code and description pair are added for the subtype.Each time the Update Subnetwork tool is run on a dirty subnetwork, a corresponding row is created, updated, or deleted in the
SubnetLinefeature class. The following are examples of changes made to theSubnetLinefeature class when updating a subnetwork:A row is added when you create a subnetwork.
An existing row is updated when changes are made to traversable features in a subnetwork.
A row is deleted when you delete a subnetwork.
A row can be added, updated, or deleted as changes are made to the Aggregated Lines for SubnetLine feature class parameter for the subnetwork definition.
When a named version is reconciled with the default version, the SubnetLine class is considered; however, when a version is posted to the default, the SubnetLine class is not included. This is because the SubnetLine class is only valid in the version in which the subnetwork was updated. After a version has been reconciled, dirty areas may need to be validated and any modified subnetworks may need to be updated again. When a version is posted to the default, dirty areas are created. After validating any dirty areas, the update subnetwork operation in the default version updates the SubnetLine class.
To use the SubnetLine feature class as a visual aid during editing tasks, set an appropriate scale suppression; for example, do not show the layer when zoomed in closer than 1:20,000. Also, apply a meaningful symbology to distinguish the collections of the subnetworks using the Subnetwork Name field.
Attributes in the SubnetLine class
Features from the SubnetLine class have the following attributes:
Field name |
Field alias |
Description |
Is dirty / Status (when creating a new utility network) |
Indicates whether a subnetwork is in a dirty, invalid, or clean state. To learn more, see Subnetwork status. |
Tier name |
The name of the tier to which the subnetwork belongs. |
Subnetwork name |
The name of the subnetwork the aggregated line or record is representing. |
Subnetwork controller names |
The names of the subnetwork controllers defining the subnetwork. |
Last update subnetwork |
The last time the subnetwork was updated using the Update Subnetwork tool. |
Last ack export subnetwork |
The last time the subnetwork was exported using the Export Subnetwork tool. Note:This attribute is only updated when Set export acknowledgement is set to true. |
You can add more fields to the SubnetLine feature class to contain summaries.
Summaries are an optional component of the subnetwork trace configuration that allow you to gather additional information about a subnetwork and store it in an attribute of the SubnetLine feature class. For example, you can use summaries in a gas network to communicate the Maximum Allowable Operating Pressure (MAOP) and output the total number of customer services for a pressure zone.
When summaries are included, a record is created in the class to display subnetwork and summary information even when a subnetwork controller is not connected to other features or when the Aggregated Lines for SubnetLine feature class parameter is not specified as part of the subnetwork definition for the tier. This creates a record with empty geometry and may be useful when you want to summarize subnetwork information when working with nonspatial network features or in situations where multiple SubnetLine features overlap, reducing the utility of the geometry while still enabling access to summary information.
