View network rules
In a utility network, network rules dictate which features can connect to or associate with other types of features. The network rule base for a utility network is accessed from the network properties of a utility network.
Access utility network rules
To access utility network rules, complete the following steps:
  1. If the utility network layer is not present in a map, add it from the Catalog pane.
  2. In the Contents pane, right-click the utility network layer and click Properties to access the layer properties.
    The properties of the utility network can also be viewed from the Catalog pane by right-clicking the utility network dataset.
  3. On the Layer Properties dialog box, click the Network Properties tab.
    For easier viewing, double-click the menu title to expand the dialog box.
  4. Scroll down on the dialog box to the Rules section. Expand this section to view information associated with each type of rule.
The network rules for a utility network are displayed.
You can access or query the Rules table from the REST endpoint using Layer ID (500003) as shown in the following examples: https://myserver.domain.com/server/rest/services/<service name>/FeatureServer/500003 and https://myserver.domain.com/server/rest/services/<service name>/FeatureServer/500003/query.
Details about each rule type
The following tables list the details for each rule type on the network properties page.
Junction-Junction Connectivity
Column
Example
ID
The ID of the rule
20
From Class
A utility network point feature class or junction object table
Electric Distribution Device
From Asset Group
The asset group of the feature class
Valve
From Asset Type
The asset type of the feature class
Double L Port
From Terminal
The terminal of the asset type participating in the rule
Port 2
To Class
Electric Distribution Junction
To Asset Group
Connection Point
To Asset Type
Fitting
To Terminal
None
Created Time
The date and time the rule was created
2017-01-17 10:05:30
Junction-Edge Connectivity
Column
Example
ID
The ID of the rule
16
From Class
From Asset Group
Transformer
From Asset Type
The asset type of the asset group
Mounted
From Terminal
High
To Class
A utility network line feature class or edge object table
Electric Distribution Line
To Asset Group
Medium Voltage
To Asset Type
Overhead
Created Time
2017-01-17 10:05:30
Edge-Junction-Edge Connectivity
Column
Example
ID
The ID of the rule
37
From Class
From Asset Group
Medium Voltage
From Asset Type
Overhead
To Class
To Asset Group
Low Voltage
To Asset Type
Overhead
Via Class
Via Asset Group
Transformer
Via Asset Type
Mounted
Via Terminal
High
Created Time
2017-01-17 10:05:30
Containment
Column
Example
ID
The ID of the rule
259
Container Class
The container feature class or table
Structure Boundary
Container Asset Group
The asset group of the container
Substation
Container Asset Type
The asset type of the container
Border
Content Class
The content feature class or table
Content Asset Group
The asset group of the content
Breaker
Content Asset Type
The asset type of the content
Circuit
Created Time
2017-01-17 10:05:30
Structural Attachment
Column
Example
ID
The ID of the rule
86
From Class
The structure feature class or table
Structure Junction
From Asset Group
Pole
From Asset Type
Wooden
To Class
The attachment feature class or table
Electric Distribution Assembly
To Asset Group
Transformer Bank
To Asset Type
3 Phase
Created Time
2017-01-17 10:05:30
