Distance units for editing
Distance and location units set as project default units appear on editing tools. The values you type in dialog boxes are automatically converted to map units. Similarly, you can add other units to a project and use them to create or modify features in maps assigned a projected coordinate system.
The following sections explain the distance and location unit settings that are available on the project Options dialog box.
For steps to add or change unit settings, see Configure unit settings for editing.
When ground to grid correction is turned on, an offset angle is applied to directions, and a distance factor multiplies distances. This occurs in real time as you create geometry using construction tools and type bearing and distance values.
To learn more, see Turn ground to grid corrections on or off.
Metric units
Distance units
Abbreviation
Meters per unit
Millimeter
mm
0.001
1/1000 meters exactly
Centimeter
cm
.01
1/100 meters exactly
Meter
m
International meter
Kilometer
km
1,000
1,000 meters exactly
Metric units
International and imperial units
Distance units
Abbreviation
Meters per unit
Inch
in
0.0254
1/12 international feet
Foot
ft
0.3048
Known as the international foot
Yard
yd
0.9144
3 international feet
Mile
mi
1,609.344
Also referred to as a statute mile, equal to 5,280 international feet
Nautical mile
nm
1,853.248
The nautical mile is a unit of distance used primarily in sea travel and aviation. The nautical mile is defined as the average distance on the earth's surface represented by one minute of latitude. In ArcGIS Desktop the United States nautical mile is used, which is 1,853.248 meters.
Link
lk
0.201168
1/100 international chain, or 66/100 international feet
Rod
rd
5.0292
1/4 chain, or 16.5 international feet
Chain
ch
20.1168
66 international feet
U.S. survey units
Distance units
Abbreviation
Meters per unit
Survey foot
ftUS
0.3048006096
Used in the state plane coordinate systems. To convert to meters, multiply U.S. survey feet by the fraction 1200/3937.
Survey mile
miUS
1,609.3472186944
5,280 survey feet.
Survey chain
chUS
20.1168402337
66 survey feet.
Survey rod
rdUS
5.0292100584
1/4 survey chain.
Survey link
lkUS
0.2011684023
1/100 survey chain.
Survey yard
ydUS
0.9144018288
3 survey feet.
U.S. survey units
Dive in:
In 1959, the National Bureau of Standards and the United States Coast and Geodetic Survey changed the definition of the yard to bring the U.S. yard and the yard used in other countries into agreement. This change redefined 1 foot as equal to 0.3048 meters exactly. The name of this new foot is international foot.
It was also decided that any data expressed in feet derived from geodetic surveys within the United States would continue to bear the relationship as defined in 1893 as 1 US Survey foot = (1200/3937) meters. The name of this foot is U.S. survey foot. The two are related to each other through the expression 1 international foot = 0.999 998 U.S. survey foot exactly.
The difference between these two values for the foot is very small, two parts per million, which is hardly measurable, but not trivial when computational consistency is desired. Fundamental survey units, such as rods, chains, statute miles, acres, sections, and townships, all depend on the relationship of 1 meter equaling 39.37 inches exactly.
