Turn on stereo display and create a stereo map
To compile 3D features in a stereo map, turn on a stereoscopic display mode and set the stereo map to a stereo data source. 3D features are edited on existing feature layers with existing editing tools and editing templates and saved to a geodatabase.
For simplicity, stereo workflows in the ArcGIS Pro editing help use the 3D cyan/red glasses stereoscopic display mode. To learn more about other stereoscopic display modes and stereo data sources, see Work with stereo mapping in ArcGIS Pro.
Tip:
To visualize your 3D edits in a scene, convert the stereo map using the To Local Scene command on the ribbon View tab. Place the two views side by side and link the pointer across the two views. To learn more about using a scene for editing, see Configure a scene for 3D editing.
To turn on stereoscopic display mode, create a stereo map, and set the stereo data source, complete the following steps:
  1. Turn on stereoscopic display mode.
    1. Click the ribbon Edit tab, click the Options dialog box launcher , and click the Display tab on the Options dialog box.
    2. Click the Stereoscopic mode drop-down menu and choose 3D cyan/red glasses.
    3. Click OK.
  2. Click the ribbon Insert tab, click the New Map drop-down menu in the Project group, and choose New Stereo Map .
  3. Click the ribbon Stereo Map tab and set the stereo data source.
    1. Click the Set Source drop-down menu in the Stereo Source group.
    2. Choose a source type and a source collection on the Set stereo source dialog box.
    3. Click OK.
