List of symbol effects
Symbol effects are components of symbols that dynamically alter feature geometry for symbol purposes. Effects are added to symbols to produce enhanced symbol depictions.
The available symbol effects are described in the following table:
Symbol effect |
Description |
Add control points |
Dynamically add control points to a line or outline to identify the placement of marker placements or geometric effects that use a template. Control points are added at vertices where the angle deflection from one segment to the next is less than the provided angle tolerance (the default is 120°). Angles between 180° and 360° are interpreted the same as angles between 0° and 180°. Angles of 180° and 360° are the same as 0°. |
Arrow
Create a dynamic line along a line feature with an arrow of a specified style and width. |
Buffer
Create a dynamic polygon with a specified diameter around a feature. |
Circular Sector
Create a dynamic polygon with a specified radius from a point. A start angle and an end angle define the width of the sector. |
Control Measure Line
Create various dynamic geometries based on the order of vertices on a line feature. The rules in this effect can be used to author parts of symbols to support ordered anchor points as defined in the Joint Military Symbology and NATO Joint Military Symbology specifications. See Control Measure Line symbol effect for details and construction guides for the rule options. |
Cut
Create a dynamic line that is cut at the beginning, middle, and optionally the ends of a line or outline. |
Dash
Create dynamic multipart line geometry from a line or polygon outline based on a template. |
Donut
Create a dynamic polygon ring of a specified width in relation to the outline of a polygon feature. |
Enclosing polygon
Create a dynamic polygon from the spatial extent of a line or polygon. |
Extension
Create a dynamic line extended from the beginning or the end of a line feature at a specified deflection angle and length. |
Jog
Create a dynamic line with a jog of a specified angle, position, and width in the line. |
Localizer Feather
Create a dynamic localizer feather of a specified length and angle originating from a point feature. |
Move
Create a dynamic geometry offset of a specified distance in x and y; it is often used to mimic a drop shadow. |
Offset
Create a dynamic line or outline offset at a specified distance perpendicular from a line or polygon feature. |
Offset Hatch
Create a dynamic multipart hatched line geometry from a line or polygon outline that is offset and mitered at joins. |
Offset tangent
Create a dynamic line that is offset from the beginning or end of a line feature at a specified distance. |
Radial
Create a dynamic line of a specified length and angle originating from a point feature. |
Regular polygon
Create a dynamic polygon around a point feature with a specified number of edges. All edges are equal in length and all angles are equal. |
Reverse
Flip the dynamic output of another geometric effect. |
Rotate
Create dynamic geometry that is rotated a specified angle from a feature. |
Scale
Create a dynamic line scaled by a specified factor from a line or outline. Vertices are moved in relation to the center point of a feature envelope. Values greater than 1 move vertices away from the center point, values between 0 and 1 move vertices toward the center point, a 0 value creates a null dynamic line, and values less than 0 draw an inverse dynamic line where the vertices have crossed to the other side of the center point. This symbol effect creates a dynamic line or outline offset at a specified distance perpendicularly from a line or polygon feature. |
Suppress
Suppress sections of line features between pairs of control points. |
Tapered polygon
Create a dynamic polygon along a line feature, whose width varies by two specified amounts along its length, as defined by a percentage of the line feature's length. |
Wave
Create a dynamic line along a line outline with a repeating wave pattern that is sinusoidal, square, triangular, or irregular. |
