Navigation options
You can customize the default navigation experience for maps and scenes in ArcGIS Pro. These settings control how you orient your view, identify features, and navigate and manage your extent. You can also customize the pointer settings for interacting with stereo maps, as well as the preferred default pop-up experience.
You can set navigation options from the application settings. In an open project, click the Project tab to open the application settings. Click the Options tab to open the Options dialog box. On the Options dialog box, under the Navigation heading, you can set the following options:
  • Mouse wheel roll forward—Controls zooming in and out on a view. By default, Zooms in is selected. With this option, when you rotate the wheel button forward, you zoom in on your view. Select Zooms out to reverse this behavior.
  • Transition time—Controls the amount of time the application takes to move from one visible extent to another. By default, this option is set to zero seconds, which updates the view extent instantaneously. You can increase the transition time to show the navigation between locations to help maintain your orientation within the view. Transition time is applied for navigation events such as zooming to a layer, navigating to a bookmark, and using the commands to go to the previous or next extent.
  • Enable panning gestures—Assists with navigation when panning maps, scenes, and layout views. When you click and release the mouse, the application assists in navigating toward the direction the mouse was released, like a push or pull to glide in that direction. This option is checked by default. If you uncheck this option, the assistance is not provided.
Tip:
Some navigation options soften the camera movement to produce a smoother navigation result, but this can lead to additional frames rendering in the view. When working with maps and scenes that have performance concerns, such as those with remote databases and services, consider using the following settings: set the transition time to 0 seconds, disable panning gestures, and for maps, open the Scale Properties dialog box and check Only display these scales when zooming.
  • Follow terrain during roam—Specific to 3D navigation, this option maintains your position above ground so it stays fixed even as you move forward, backward, uphill, or downhill. The view avoids bumping into or going through hills and can be useful when using roam near street-level navigation in hilly cities. When this option is checked, the wheel button can still be used for zooming in and out and changing the camera's altitude. This option is not checked by default.
  • Show distance to cursor—Specific to 3D navigation, this option displays the straight-line distance from your view position to a location in the view, such as a mountaintop or corner of a building. The value displays in the status bar at the bottom of the view, next to the coordinate display units. This option is not checked by default and the text is not shown in stereo views.
  • Show navigation scrollbars (2D only)—Adds a horizontal and vertical scrollbar to the edge of a map. Click the arrows to pan 10 percent of the current view in that direction, or click within the scrollbar to pan 50 percent of the current view. Not available for scenes.
  • First person navigation speed exaggeration—Specific to 3D navigation, this controls the initial camera travel speed when first-person navigation mode is enabled.
  • On Screen Navigator
    • Show Navigator when opening 2D views—By default, no navigator control shows when a new 2D map view is opened. You can optionally configure 2D maps to open always showing the navigator using Heading or Full Control mode.
    • Show Navigator when opening 3D views—By default, the navigator control shows in Heading mode, allowing you to know where north is and click to reset the view to north. Drag the outer ring to pan around the scene. Optionally, configure 3D views to open with the navigator maximized for full control or no navigator at all.
    • Default Navigator size—Adjusts the initial size of the navigator as it will appear each time in a view.
  • Pop-ups
    • Use classic pop-up mode—Overrides the default styling and uses the classic pop-up styling at all times.
    • Honor dark theme—Pop-ups honor the dark theme when the application is in this mode. This option is on by default. Turn it off to display the attribute portion of pop-ups in the light theme styling regardless of the application setting.
    • Block JavaScript content—Blocks pop-ups that contain JavaScript content. This option is on by default.
      If you are an administrator who wants to block JavaScript content in all pop-ups for the machine, you can do so by creating the following value in the Windows registry:
      HKEY_LOCAL_MACHINE\Software\ESRI\ArcGISPro\Settings\BlockPopupJavaScript
      To restrict nonadministrator users from enabling this option, set this value to 1. Set the value to 0, or delete the value entirely, to allow nonadministrator users to control pop-up content.
    • Show crosshairs when flashing—Displays four lines that draw from the outer edge of the map view to center on a flashed feature.
    • Include the selection buffer when identifying features—Includes the selection pixel buffer when performing a single-click identification. The size of this buffer can be changed on the Selection tab. In a 2D map, a circular buffer is applied, while in a 3D scene, a cube is used.
    • Show pop-up title—Show the blue pop-up title at the top of the attribute portion of a pop-up.
    • Show feature coordinate value—Show the coordinate value of a feature at the bottom of the pop-up.
