Share a pop-up configuration as a file
You can share a pop-up configuration (.pop file) between layers or projects. A .pop file includes the arrangement of pop-up elements and their settings.
No data is included in a .pop file. To share data along with a pop-up configuration, it is recommended that you share a layer package.
Legacy:
Pop-up files were introduced at ArcGIS Pro 3.5 and cannot be imported by earlier versions of ArcGIS Pro.
Create a pop-up configuration file
To create a pop-up configuration file, complete the following steps:
In the Pop-up Configuration pane, click the menu button
and click Save Pop-up Configuration.Browse to the location where you want to save the file.
Provide a file name.
Click Save.
The .pop file is created.
Import a pop-up configuration file
To use a pop-up configuration file to define the pop-up of a layer, complete the following steps:
and click Load Pop-up Configuration.Browse to the location of the
.popfile you want to import.Select it and click OK.
The pop-up configuration updates to reflect the configuration of the specified file.
