General label settings
ArcGIS Pro has global parameters you can use to control how labels are placed. These settings are saved for each map.
Because these are global parameters, you set them on the Map Properties dialog box, which you can open by right-clicking the map in the Contents pane and clicking Properties and the Labels tab.
Color for unplaced labels
This setting controls the color of the labels that could not be placed on the map. By default, unplaced labels are drawn in red. If your map already contains many red labels, you can change the color of the unplaced labels to something different.
Orientation of vertical labels
Labels are typically placed to read from left to right, following the convention of most Western languages. When labeling nearly vertical line features, the natural break point would be at 0 degrees, or due north. In places where the streets are laid out in a north–south/east–west-oriented grid, the labels of nearly parallel streets may be placed in opposite directions. It is recommended that nearly parallel streets be labeled in the same direction.
The angle set in the Orientation of vertical labels parameter controls whether the label is placed slightly upside down or flipped to the opposite direction. A small angle prevents labels from switching their reading order when labeling nearly vertical lines. Specify a positive value if you want labels that are close to vertical to generally read from the right side of the page or screen, and specify a negative value if you want these labels to generally read from the left. For example, suppose you have two lines, one of which is oriented 6 degrees east of north and the other of which is oriented 6 degrees west of north. The first will have a label that is read from south to north (left to right). If you specify an angle of 0, the label of the second line would be flipped to read from north to south, rather than placed slightly upside down. If you want to have some labels slightly upside down to keep a consistent reading direction, increase the angle—in this case, to more than 6 degrees. Using a negative angle forces the labels to change direction at a given angle east of north. The default angle is 2 degrees, and the maximum angle is 30 degrees. The angle also applies to north–south-oriented polygons or their boundaries when using the Straight and Boundary label positions. When a nearly vertical label is flipped to match the Orientation of vertical labels value, its position above or below relative to the feature is also flipped.
Rotate point and polygon labels when map is rotated
You can rotate maps using the navigation tools. The Rotate point and polygon labels when map is rotated option controls whether point and polygon labels are rotated when the map is rotated.
Line labels, nonhorizontal polygon labels, and non-Maplex Label Engine point labels based on a field value always rotate with the map.
Nonhorizontal polygon labels always rotate with the map because they have the potential to be placed at the best polygon angle. Therefore, after map rotation, the labels are replaced, which means that they are effectively rotated to the new polygon feature orientations.
Allow labels to overlap border (Maplex Label Engine only)
In addition to the standard global label settings, Maplex Label Engine provides another parameter to control how labels for all layers are placed.
By default, labels are placed within the border of the map. You can allow parts of labels to overlap the border to increase the likelihood that they will be placed, although the part of the label outside the border will not be visible on the map. This is useful when making a map series and merging map tiles, where it may be desirable to have the label placed on the map (albeit running into the next tile) so it is available when editing the map border.
The Maplex Label Engine Overrun parameter is used to control how much of the label is placed outside of the map.
The following image shows the label on the left overlapping the map border. This label should read Wood County:
