Specify a minimum feature size for labeling
A way to control label density in an area is to reduce the number of small features that are being labeled. If your layer contains many small insignificant features that do not require a label, you can use the Maplex Label Engine to remove the features from the list of features to be labeled.
The Minimum feature size property is only available for line and polygon features. For line labeling, the value is specified as the length of the line in the current map units or in page units—millimeters, inches, or points. For polygon labeling, the value is specified as the length of the polygon perimeter or the area in map units or in page units—millimeters, inches, or points.
In the image below, the minimum feature size was set to 300 square kilometers.
Minimum feature size of 300 sq km
  1. Ensure that the Maplex Label Engine is enabled.
  2. Ensure that List By Labeling is the active method of displaying the Contents pane. Click the List By Labeling tab .
  3. Choose a label class in the Contents pane, and click the Labeling tab.
  4. On the Labeling tab, in the Label Placement group, click Label Placement Properties .
  5. In the Labeling pane, click Position, and click the Conflict resolution tab .
  6. Expand Minimum feature size.
  7. Specify the Minimum for labeling size and the units to measure in (map units or page units—millimeters, inches, or points).
    When labeling polygon features, specify whether minimum feature size is for Perimeter or Area.
