Complex scenarios for route calibration
Available with Location Referencing license.
The following are scenarios for route calibration of complex routes that include loop, branch, lollipop, and alpha routes.
Calibration on a loop route
In the following example, a calibration point is added in the middle of a loop route (RouteX) using a different measure (3) than the existing measure (2). Since Recalibrate route downstream is checked, downstream measures are updated.
Example 1: Input for calibration on a loop route
A calibration point is added using the new measure (3). All downstream measures on RouteX are updated.
Example 1: Output for calibration on a loop route
Calibration on a branch route
In the following example, a calibration point is added on a branch route (RouteX) using a different measure (9) than the existing measure (4.5). Since Recalibrate route downstream is checked, downstream measures are updated.
Example 1: Input for calibration on a branch route
A calibration point is added using the new measure (9). All downstream measures are updated.
Example 1: Output for calibration on a branch route
Calibration on a lollipop route
In the following example, an existing calibration point (0) at the beginning of a lollipop route (RouteX) is updated using a new measure (5). Since Recalibrate route downstream is checked, downstream measures are updated.
Example 1: Input for calibration on a lollipop route
The calibration point is updated using the new measure (5). All downstream measures are updated.
Example 1: Output for calibration on a lollipop route
Calibration on an alpha route
In the following example, an existing calibration point (2.33) on an alpha route (RouteX) is updated using a new measure (3.33). Recalibrate route downstream is checked.
Example 1: Input for calibration on an alpha route
The calibration point is updated using the new measure (3.33). All downstream measures are updated.
Example 1: Output for calibration on an alpha route
