Create events using the attribute table
Available with Location Referencing license.
You can add an event to an event layer in a feature service by adding a row to the layer's attribute table. The event record is generated when at least a route ID and measures are provided.
Right-click the event layer to which you want to add an event, and choose Attribute Table to open its attribute table in the ArcGIS Pro subpanel. To add an event record, click in the first empty row, and provide at least a route ID and measures for the event.
If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled.
Depending on the event type—point event, line event, or spanning line event—the following are required to generate the event shape on the map:
  • To add a point event to a point event layer using its attribute table, you must include a route ID and a measure.
  • To add a line event to a line event layer using its attribute table, you must include a route ID, starting measure, and ending measure.
  • To add a spanning event, you must include the starting route ID, ending route ID, starting measure, and ending measure.
After edits are made to the attribute table row, the system-provided Location Error value is updated to indicate the status.
Learn more about time slicing an event
Events that have stationing and referents configured are supported in ArcGIS Pro. When editing a referent or stationing event in the attribute table, you can provide the values for the stationing or referent columns; however, the event is drawn based only on the values provided in the measure fields.
You can provide an event ID; if you don't, the system automatically generates a GUID that serves as the event ID.
Location Errors
If the feature is added outside the tolerance value and the route ID or measures are not detected, a location error occurs.
You can also view a complete list of location errors.
Any of the following statuses indicate a problem that should be resolved:
Location error
Different From Route And To Route Line IDs
The starting route and the ending route have different line IDs. This is applicable to events associated with line networks.
Invalid Route Line ID
The route's line ID is invalid. This is applicable to events associated with line networks.
Invalid Location Route ID
The route location's route ID is invalid (NULL, empty, or invalid value).
Invalid Location Measure
At least one of the route location's measure values is invalid.
Invalid Route ID
Measure Extent Out Of Route Measure Range
The route location's shape doesn't exist on the route. The route has no m-values, or the route location's measures don't exist on the route.
Multiple Route Locations Found
More than one point location was found. Measures may not be unique along the routes.
Null Extent
The start measure is equal to the end measure.
Parent Event Not Found
The route location's shape was not found because the start measure and the end measure are outside the route measures.
Partial Match For The From Measure and To Measure
The start measure and the end measure are outside the route measure range.
The start measure is outside the route measure range.
Partial Match For The To Measure
The end measure is outside the route measure range.
Reversed Line Order
The starting route does not have a lower line order than the ending route. This is applicable to line networks.
Route Location Not Found
Route Not Found
The route does not exist. This may be due to the route not existing in the network or the route and event having different time ranges that do not overlap.
Route Shape Empty
The route does not have a shape, or the shape is empty.
Scenarios for adding a line event using the attribute table
The scenarios below detail the results of adding a line event to an event layer by opening its attribute table and adding a new row to associate an event (Event1) to Route1.
When adding an event using the attribute table, if a route has multiple time slices and the new event has its start date and end date both set as <Null>, the event is added to the latest time slice of the route.
Add a line event
The route (Route1) has measures from 0 to 20 before a line event is associated with it.
Before adding a line event to a nonspanning route
The following table details the route attributes. Valid measures for an event on Route1 must be between 0 and 20, and valid dates must fall on 1/1/2000 or later.
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
The following table details the event when it is resolved to the No Error value in the Location Error field:
Event
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Speed Limit
Event1
Route1
1/1/2000
<Null>
10
20
No Error
55
The following diagram shows the route and its associated event after its shape is generated:
After adding a line event to a nonspanning route
Add a line event resulting in a location error
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
The following table details the event when it is resolved to the Partial Match For To Measure value in the Location Error field. In this case, the match is partial because the route ends at 20, not 30. The event shape is generated but ends at the route's actual end measure of 20.
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Speed Limit
Route1
1/1/2000
<Null>
10
30
Partial Match for To Measure
55
In such a case, provide a valid end measure for the route to resolve the location error.
The following diagram shows the event on Route1:
After adding a line event to a nonspanning route resulting in a partial match error
Scenarios for adding a spanning event using the attribute table
The scenarios below detail the results of adding spanning event values in the layer's attribute table.
Add a spanning event
The following diagram shows the routes and their associated event before the edit:
Before adding a line event to a spanning route
The following table details the route attributes. Valid measures for an event on LineA must be between 0 on Route1 and 40 on Route3, and valid dates must fall on or after 1/1/2000.
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
Route2
1/1/2000
<Null>
Route3
1/1/2000
<Null>
When the From Route ID, From Measure, To Route ID, To Measure, date, and other attributes are provided in the attribute table, the location error is calculated and a shape is generated for the event. In this case, Event1 is a spanning event that has measures from 5 on Route1 to 35 on Route3.
Event
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
Speed Limit
Event1
Route1
Route3
1/1/2000
<Null>
35
No Error
55
The following diagram shows the routes after the spanning line event is added:
After adding a line event to a spanning route
Add a spanning event resulting in a location error
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
Route2
1/1/2000
<Null>
Route3
1/1/2000
<Null>
The following table details the event when it is resolved to the Partial Match For From-Measure value in the Location Error field. Since a valid event on Route2 can exist only between the measures 15 and 25, the event shape is generated using 15.
Event
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
Speed Limit
Event1
Route2
Route3
1/1/2000
<Null>
10
35
55
In such a case, provide a valid measure for Route2 in the From Measure cell to resolve the location error.
After adding a spanning line event
Referent offset and event creation using the attribute table
The Roads and Highways events data model supports the configuration of referent event fields and their enablement using the Enable Referent Fields tool. Once referent fields are configured and enabled in a layer, referent locations are populated and persisted in that layer when events are added or edited.
When an event is created using the attribute table, it inherits the route and measure behavior for a referent-enabled layer.
If either measure of a line event is updated, the corresponding offset value updates to reflect the new measure.
The examples below demonstrate the impact of creating event records in a referent-enabled layer by adding a row to the attribute table.
Before adding a line event with referents
The following diagram shows the route before event creation using the attribute table:
Before attribute table event creation with referents
The following table provides details about the route:
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
After adding a line event with referents
The following diagram shows a line event that has been added to an event layer that has referents enabled:
After attribute table event creation with referents
The following table provides details about the event referent fields after event creation:
FromRefMethod
FromRefLocation
FromRefOffset
ToRefMethod
ToRefLocation
ToRefOffset
AllRoutes
Route1
AllRoutes
Route1
20
The following table provides details about the default event fields after event creation:
Event ID
From Date
To Date
From Measure
To Measure
Event1
1/1/2000
<Null>
You can edit the event using the attribute table so that it uses referents other than the default values. If subsequent route edits are made, the RefMethod and RefLocation values revert to the parent LRS Network and the route, respectively.
