Event editing using feature edits
Available with Location Referencing license.
You can edit an event feature in a feature service event layer using the Edit Vertices tool
Using this method, you can edit an existing event shape. The event’s route ID, route name, and measures are updated accordingly. The event’s dates do not change.
When an event is moved from one route to another route, the event's time slice is based on the route's start and end dates.
When you edit a point event, the route ID and measure are updated based on the underlying route. When editing a line event feature, the first vertex is used to populate the From Measure and From Route fields, and the last vertex is used to populate the To Measure and To Route fields. For spanning line event features, the start and end measures must be on routes that have the same line ID.
Learn more about editing features using standard editing tools in ArcGIS Pro
If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled.
After a route is selected, the tool will attempt to release the route lock if the route lock is acquired by the active user in a different version and its releasable status value is Yes.
After editing an event’s vertices, you can retire the existing event and create a new event with a start date (From Date) as of the specified retire date including the edited vertices. You can also merge any coincident line events. For more information, refer to the event editing options under Location Referencing options in ArcGIS Pro.
Location Errors
The location error attributes provide information about the status of each event feature. When an event feature is edited correctly, the No Error value is displayed in the location error field of the event. If the status is anything other than No Error, inspect the modified event feature and its attributes for issues and resolve them.
You can also view a complete list of location errors.
Any of the following statuses indicate a problem that should be resolved:
Location error |
Description |
Different From Route And To Route Line IDs |
The starting route and the ending route have different line IDs. This is applicable to events associated with line networks. |
Invalid Location Route ID |
The route location's route ID is invalid (NULL, empty, or invalid value). |
Invalid Location Measure |
At least one of the route location's measure values is invalid. |
Invalid Route ID |
Reversed Line Order |
The starting route does not have a lower line order than the ending route. This is applicable to line networks. |
Route Not Found |
The route does not exist. This may be due to the route not existing in the network or the route and event having different time ranges that do not overlap. |
Scenarios for editing line events using feature edits
The scenarios below detail the results of editing event features using the Edit Vertices tool
Editing a line event
The following diagram shows the route and its associated event. Route1 has measures from 0 to 20, and Event1 has measures from 0 to 10.
The following table details the route attributes:
Route ID |
From Date |
To Date |
Route1 |
1/1/2000 |
<Null> |
The following table details the event before editing:
Route ID |
From Date |
To Date |
Route1 |
1/1/2000 |
<Null> |
Event ID |
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
1/1/2005 |
<Null> |
0 |
10 |
No Error |
55 |
To edit the event so that it runs from 0 to 20, where the intersection with Route2 is located, drag the last vertex of the event to the intersection using the Edit Vertices tool
. The first vertex is used as the starting measure, and the last vertex is used as the ending measure.
The following diagram shows the event after editing:
The following table details the event after editing:
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Route1 |
1/1/2005 |
<Null> |
0 |
20 |
No Error |
55 |
Editing a line event resulting in a location error
The following diagram shows the route and its associated event. Route1 has measures from 0 to 20, and Event1 has measures from 0 to 15.
Route ID |
From Date |
To Date |
Route1 |
1/1/2000 |
<Null> |
The following table details the event before editing. Event1 on Route1 has measures from 0 to 15.
Event ID |
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
1/1/2000 |
<Null> |
0 |
15 |
No Error |
55 |
During the edit, Event1 is dragged beyond the intersection and beyond the end of Route1. In this case, the event's shape remains intact and a location error occurs.
The following table details Event1. Since the event's end measure cannot be located, a location error occurs.
Event ID |
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
1/1/2000 |
<Null> |
10.5 |
<Null> |
55 |
The following diagram shows the route after relocating the end vertex of the line event (Event1) on Route1:
Scenarios for editing spanning events using feature edits
The following scenarios detail the results of editing event features on the map using the Edit Vertices tool
or the Move tool
Editing a spanning event
The following diagram shows the routes and their associated event. Route1 and Route2 are on LineA.
Route ID |
From Date |
To Date |
Route1 |
1/1/2000 |
<Null> |
Route2 |
1/1/2000 |
<Null> |
Event |
From Route ID |
To Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
Route2 |
1/1/2000 |
<Null> |
0 |
25 |
No Error |
55 |
In this case, the event is edited so that the start vertex of the event is snapped to measure 0 on Route1, and the end vertex of the event is snapped to end measure 25 of Route2.
Event |
From Route ID |
To Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
Route2 |
1/1/2000 |
<Null> |
0 |
25 |
No Error |
55 |
The following diagram shows the route and its associated event after the edit:
Editing a spanning event resulting in a location error
The following diagram shows the routes and their associated event. Route1 and Route2 are on LineA, and RouteX1 is on LineB. Event1 spans from measure 5 on Route1 to measure 20 on Route2.
The following table details the route attributes. RouteX1 is located on LineB.
Route ID |
From Date |
To Date |
Route1 |
1/1/2000 |
<Null> |
Route2 |
1/1/2000 |
<Null> |
RouteX1 |
1/1/2000 |
<Null> |
Event ID |
From Route ID |
To Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
Route2 |
1/1/2000 |
<Null> |
5 |
20 |
No Error |
55 |
In the following diagram, the event is edited so that the last vertex of the event is snapped to measure 35 of RouteX1, which is on a different line (LineB).
The following table details Event1 after editing. Because the event's ending measure cannot be located on the same line, the event is drawn only up to the end of Route2 on LineA and a location error describing the issue is provided.
Event |
From Route ID |
To Route ID |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Speed Limit |
Event1 |
Route1 |
RouteX1 |
1/1/2000 |
<Null> |
5 |
35 |
Different From-Route and To-Route Line IDs |
55 |
The following diagram shows Event1 after the error. The event is generated without the LineB segment.
Referent offset when using feature edits
The Roads and Highways events data model supports the configuration of referent event fields and their enablement using the Enable Referent Fields tool. Once referent fields are configured and enabled in a layer, referent locations are populated and persisted in that layer when events are added or edited.
When a line event is edited using feature edits in a referent-enabled layer, the parent LRS Network is used as the FromRefMethod and ToRefMethod values by default, and the route is used as the FromRefLocation and ToRefLocation values. The start and end measures of the line event are used as the FromRefOffset and ToRefOffset values.
If either measure of a line event is updated, the corresponding offset value updates to reflect the new measure.
The example below demonstrates the impact of editing events that have user-configured referent values enabled in the event layer.
Before editing with referents
The following diagram shows the route and its associated events:
The following table provides details about the event referent fields before the edit:
FromRefMethod |
FromRefLocation |
FromRefOffset |
ToRefMethod |
ToRefLocation |
To Ref Offset |
PointEventLayer1 |
Point1 |
5 |
PointEventLayer1 |
Point1 |
15 |
The following table provides details about the default event fields before the edit:
Event ID |
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
<Null> |
10 |
20 |
After editing with referents
When applying feature edits to an event record that has user-configured referent fields, the FromRefMethod and ToRefMethod values revert to the parent LRS Network, and the FromRefLocation and ToRefLocation values revert to the route.
The following table provides details about the event referent fields after event editing:
FromRefMethod |
FromRefLocation |
FromRefOffset |
ToRefMethod |
ToRefLocation |
To Ref Offset |
AllRoutes |
Route1 |
5 |
AllRoutes |
Route1 |
15 |
The following table provides details about the default event fields after the edit:
Event ID |
Route ID |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
<Null> |
5 |
15 |
