Route reassignment
Available with Location Referencing license.
Reassignment is the technique by which all or a portion of a route or line is moved, or reassigned, to the immediate upstream or downstream of another route or line. One example is to redesignate a portion of a road that now falls on the other side of a boundary after administrative boundaries change.
The Reassign Route tool can be used to perform route reassignment and update attributes and calibration points located along the reassigned route.
Scenarios that can be accomplished using the Reassign Route tool are described below.
In the scenarios described below, you can select entire routes or partial routes.
Route merges to an existing route
RouteX and RouteY are adjoining routes. You can use the Reassign Route tool to merge RouteX with RouteY or vice versa. The existing RouteX and RouteY are retired and a new RouteY is created on the date of reassignment. You can merge the reassigned portion to any immediate upstream or downstream route.
The date of reassignment is 1/1/2010.
RouteX ends where RouteY starts.
Output for merging to an existing route
The following shows routes before reassignment:
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
The following are inputs used for the Reassign Route tool:
Method
Merge to adjacent route
Source
Route ID
RouteX
From Measure
To Measure
20
Target
Route ID
RouteY
From Measure
To Measure
20
The following show routes after reassignment:
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteY
1/1/2010
<Null>
Split to an existing route
RouteXYZ has measures from 0 to 30. In the following example, the route is split in two: a new Route1 and a new version of RouteXYZ. The existing RouteXYZ is retired as a result of this operation.
Input for splitting existing RouteXYZ
Output for splitting existing RouteXYZ with a new Route1
The following shows the route before reassignment:
Route ID
From Date
To Date
RouteXYZ
1/1/2005
<Null>
Method
Form a new route
Source
Route ID
RouteXYZ
From Measure
To Measure
19
Target
Route ID
Route1 (new)
From Measure
10
To Measure
29
The following shows routes after reassignment:
Route ID
From Date
To Date
RouteXYZ
1/1/2005
1/1/2010
RouteXYZ
1/1/2010
<Null>
Route1
1/1/2010
<Null>
Route is renamed
You can rename an existing route and change its start (From) and end (To) measure values using the Reassign Route tool. In the following example, RouteXYZ is renamed Route123 and contains new measures. The existing RouteXYZ is retired as a result of this operation.
If all route records across all time slices need to be renamed without creating more time slices, use the Rename Route tool.
Input for renaming RouteXYZ
Output for renaming a route when RouteXYZ is renamed Route123 and retired
Route ID
From Date
To Date
RouteXYZ
1/1/2005
<Null>
Method
Form a new route
Source
Route ID
RouteXYZ
From Measure
To Measure
30
Target
Route
Route123
From Measure
15
To Measure
45
Route ID
From Date
To Date
RouteXYZ
1/1/2005
1/1/2010
Route123
1/1/2010
<Null>
Calibration point transfers to a target route
Routes may contain calibration points to maintain known measures between points. When reassigning the route, there is an option to transfer the calibration points contained in the reassigned portion to the target route.
The option to transfer calibration points to a target route during reassignment is checked by default and is the preferred method to maintain established measures.
Input for transferring calibration points to a target route
Output for transferring calibration points to a target route
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
Route ID
RouteX
From Measure
To Measure
20
Target
Route
RouteY
From Measure
To Measure
30
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteY
1/1/2010
<Null>
Downstream recalibration
The following examples describe downstream recalibration. You can choose whether to recalibrate the source route downstream when you reassign routes.
Reassignment with the source route not calibrated downstream
RouteX is split into two routes: RouteX and Route1. Route1 starts at the beginning of the old RouteX and ends at the middle of the old RouteX. The end measure value for the new Route1 is set as 3 instead of the suggested measure of 5. The downstream measures for RouteX remain intact because the Recalibrate route downstream check box is unchecked for the source route.
A source route before reassignment of a RouteX section is split and not calibrated downstream
Newly reassigned section of Route1 and RouteX with the source route not calibrated downstream
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
The following are the inputs used for the Reassign Route tool:
Method
Form a new route
Source
From Route
RouteX
From Measure
To Route (This option is only for line networks.)
RouteX
To Measure
Target
Route
Route1 (new)
From Measure
To Measure
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
<Null>
RouteX
1/1/2010
<Null>
Route1
1/1/2010
<Null>
Reassignment with the source route calibrated downstream
RouteX is split into two routes: RouteX and Route1. Route1 starts at the beginning of the old RouteX and ends at the middle of the old RouteX. The end measure value for the new Route1 is set as 3 instead of the suggested measure of 5. If the Recalibrate route downstream check box is checked for the source route, the downstream route's (RouteX) measures change to a start measure value of 0 and an end measure value of 5.
A source route before reassignment of a RouteX section is split and calibrated downstream
Newly reassigned section of Route1 and RouteX with the source route calibrated downstream
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Form a new route
Source
From Route
RouteX
From Measure
RouteX
To Measure
Target
Route
Route1 (new)
From Measure
To Measure
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
<Null>
RouteX
1/1/2010
<Null>
Route1
1/1/2010
<Null>
Reassignment with the target route calibrated downstream
A part of RouteX is merged with the adjoining route, RouteY. The reassignment takes place from the middle of RouteX on the downstream side. Because the Recalibrate route downstream check box is checked for the target route, the measure of RouteY downstream of the reassigned portion is recalibrated. The new version of RouteY now has an end measure value of 9.
Input for reassignment of a section of RouteX merged with RouteY with the target route calibrated downstream
Output for reassignment with the target route calibrated downstream
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
From Route
RouteX
From Measure
To Measure
10
Target
Route
RouteY
From Measure
To Measure
9
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteX
1/1/2010
<Null>
RouteY
1/1/2010
<Null>
Complex route reassignment scenarios
Complex route reassignment scenarios for complex routes and shapes, including loop, lollipop, branch, and barbell shapes are described below.
Reassignment resulting in a loop
In the following example, RouteX and RouteY are merged to create a loop route after reassignment. RouteX has measures 0 to 2, and RouteY has measures 2 to 4:
Example 1: Input for reassignment resulting in a loop
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
From Route
RouteX
From Measure
To Measure
Recalibrate source route
No
Target
To Route
RouteY
From Measure
To Measure
Recalibrate target route
Yes
The date of reassignment is 1/1/2010. After reassignment, a calibration point is added at measure 1, and RouteY is recalibrated with measures 0 to 4.
Example 1: Output for reassignment resulting in a loop
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteY
1/1/2010
<Null>
Split to an existing loop
In the following example, RouteX, on a loop with measures 0 to 12, is split and the edit section is reassigned to a new route (RouteY):
Example 1: Input for splitting an existing loop
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
Method
Form a new route
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
The date of reassignment is 1/1/2010. After reassignment, RouteY is created with measures 0 to 4. The calibration point formerly at 8 is updated to 4, and RouteX is recalibrated with measures 0 to 8.
Example 1: Output for splitting an existing loop
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteX
1/1/2010
<Null>
RouteY
1/1/2010
<Null>
Reassignment resulting in a lollipop
RouteX has measures 0 to 4 and RouteY has measures 0 to 1. In the following example, a loop route (RouteX) is merged with a simple route (RouteY) to create a lollipop route after reassignment:
Example 1: Input for reassignment resulting in a lollipop
Route ID
From Date
To Date
RouteY
1/1/2005
<Null>
RouteX
1/1/2005
<Null>
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
To Route
RouteY
From Measure
To Measure
Yes
The date of reassignment is 1/1/2010. After reassignment, the resulting lollipop route (RouteY) has updated measures 0 to 5.
Example 1: Output for reassignment resulting in a lollipop
Route ID
From Date
To Date
RouteY
1/1/2005
1/1/2010
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2010
<Null>
Splits to an existing lollipop
RouteX has measures 0 to 5 and RouteY has measures 0 to 1. In the following example, the stick portion of a lollipop route (RouteX) is split and reassigned to an existing route (RouteY):
Example 1: Input for splitting an existing lollipop
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
From Route
RouteX
From Measure
To Measure
Yes
Target
To Route
RouteY
From Measure
To Measure
Yes
The date of reassignment is 1/1/2010. After reassignment, both routes are recalibrated. The updated simple route (RouteY) has measures 0 to 2, and the loop route (RouteX) has measures 0 to 4.
Example 1: Output for splitting an existing lollipop
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteX
1/1/2010
<Null>
RouteY
1/1/2010
<Null>
Routes that merge to create a barbell
In the following example, a loop route (RouteX) with measures 0 to 4 is merged with a lollipop route (RouteY) that has measures from 0 to 5:
Example 1: Input for merging multiple routes to create a barbell
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
From Route
RouteX
From Measure
To Measure
No
Target
Target Route
RouteY
From Measure
To Measure
9
Yes
The date of reassignment is 1/1/2010. After reassignment, a new barbell route (RouteY) is created from the merged routes. RouteY has recalibrated measures from 0 to 9.
Example 1: Output for merging multiple routes to create a barbell
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteY
1/1/2010
<Null>
Simple route merges to create a branch
In this example, a simple route (RouteY) is merged to another simple route (RouteX) to create a branch route after reassignment. RouteX has measures 0 to 6, and RouteY has measures from 5 to 10.
Example 1: Input for merging simple routes to create a branch
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
RouteY
1/1/2005
<Null>
Method
Source
From Route
RouteY
From Measure
To Measure
10
No
Target
To Route
RouteX
From Measure
6
To Measure
11
Yes
The date of reassignment is 1/1/2010. After reassignment, RouteY is merged with RouteX to create a branch route with recalibrated measures 0 to 11.
Example 1: Output for merging simple routes to create a branch
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteY
1/1/2005
1/1/2010
RouteX
1/1/2010
<Null>
Splits on an infinity route
In the following example, an existing infinity route (RouteX) with measures 0 to 24 is split to create an alpha route and a new simple route (RNew):
Example 1: Input for splitting an infinity route
Route ID
From Date
To Date
RouteX
1/1/2005
<Null>
Method
Form a new route
Source
From Route
RouteX
From Measure
18
To Measure
24
Yes
Target
To Route
RNew
From Measure
To Measure
6
The date of reassignment is 1/1/2010. After reassignment, RouteX is an alpha route with measures 0 to 18, and RNew has measures 0 to 6.
Example 1: Output for splitting an infinity route
Route ID
From Date
To Date
RouteX
1/1/2005
1/1/2010
RouteX
1/1/2010
<Null>
RNew
1/1/2010
<Null>
Route reassignment in a line network
Routes in a line network can be reassigned to new or existing routes as shown in the following examples.
Multiple routes merge to a new route
RouteX, RouteY, and RouteZ are consecutive routes that belong to the same line, Line1. You can use the Reassign Route tool to merge all of them together into a new route, RouteXYZ, which belongs to the same line.
Diagram of route before reassignment Diagram of route that is merged after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line1
1/1/2005
<Null>
300
Method
Form a new route
Source
From Route
RouteX
From Measure
10
To Route
RouteZ
To Measure
60
Target
Route
RouteXYZ
From Measure
To Measure
30
RouteXYZ has the line order of 100. RouteX, RouteY, and RouteZ are retired as a result of this operation. You can choose new start and end measure values for RouteXYZ.
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
1/1/2010
100
RouteY
Line1
1/1/2005
1/1/2010
200
RouteZ
Line1
1/1/2005
1/1/2010
300
RouteXYZ
Line1
1/1/2010
<Null>
100
  • Both the From Route and the To Route values from the Source section can be partially reassigned.
  • Line orders of the remaining routes in the source line may be recalculated as a result.
RouteX and RouteY are consecutive routes that belong to Line1. You can use the Reassign Route tool to merge them with RouteZ, which belongs to the adjoining Line2.
Diagram of routes to be merged into a single route before reassignment Diagram of merged routes into a single route after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line2
1/1/2005
<Null>
100
The following inputs are used for the Reassign Route tool:
Method
Source
From Route
RouteX
From Measure
10
To Route
RouteY
To Measure
40
Target
Route
RouteZ
From Measure
To Measure
30
The target is recalibrated downstream.
RouteX, RouteY, and RouteZ are retired because of this operation. In this case, the reassign portion is from the start of RouteX to the end of RouteY.
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
1/1/2010
100
RouteY
Line1
1/1/2005
1/1/2010
200
RouteZ
Line2
1/1/2005
1/1/2010
100
RouteZ
Line2
1/1/2010
<Null>
100
  • Any one of the From Route and To Route values from the Source section can be partially reassigned to any immediate upstream or downstream route.
  • Routes from one line can be merged to an adjoining route in another line. Either of the From Route or To Route values from the Source section of one line should be touching either the start or end of the target route in another line.
  • Routes from a line can be merged to an existing adjoining route in the same line.
Route splits
RouteZ has measures from 40 to 60. As shown in this example, you can split the route into two: RouteY, which is a new route, and a new version of RouteZ.
Diagram depicting route before splitting Diagram depicting routes split after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteZ
Line1
1/1/2005
<Null>
200
Method
Form a new route
Source
From Route
RouteZ
From Measure
40
To Route
RouteZ
To Measure
50
Target
Route
RouteY
From Measure
30
To Measure
40
The source is not recalibrated downstream.
The existing RouteZ retires as a result of this operation. RouteY has the line order of RouteZ, and the new version of RouteZ has the next line order value.
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteZ
Line1
1/1/2005
1/1/2010
200
RouteY
Line1
1/1/2010
<Null>
200
RouteZ
Line1
1/1/2010
<Null>
300
  • Choose the same From and To source route to split a single route.
Route splits and merges
RouteY has measures from 30 to 40. As shown in this example, you can split the route and then merge one of the parts to the adjoining route RouteZ.
Diagram depicting route before splitting and merging Diagram depicting route after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line1
1/1/2005
<Null>
300
The following are inputs for the Reassign Route tool:
Method
Source
From Route
RouteY
From Measure
35
To Route
RouteY
To Measure
40
Target
Route
RouteZ
From Measure
50
To Measure
55
The Recalibrate route downstream check box is checked. The existing RouteY and RouteZ retire because of this operation. The new version of RouteY has the same line order as the previous one. The other split part of RouteY is merged to RouteZ.
Route Name
Line Name
From Date
To Date
Line Order
RouteY
Line1
1/1/2005
1/1/2010
200
RouteZ
Line1
1/1/2005
1/1/2010
300
RouteY
Line1
1/1/2010
<Null>
200
RouteZ
Line1
1/1/2010
<Null>
300
Route is renamed
You can rename an existing route and change its start and end measure values with the help of the Reassign Route tool. RouteX is renamed RouteX_New and has new measures. The line order remains the same. The existing RouteX retires because of this operation.
Diagram depicting route before reassignment Diagram depicting route after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
Tip:
Use the Rename Route tool to rename all of the route records across all of the time slices without creating more time slices.
Method
Form a new route
Source
From Route
RouteX
From Measure
10
To Route
RouteX
To Measure
20
Target
Route
RouteX_New
From Measure
10.1
To Measure
20.1
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
1/1/2010
100
RouteX_New
Line1
1/1/2010
<Null>
100
Route transfers to an existing line
Routes can be transferred entirely or partially to an existing line. In this case, the reassign portion should be either on the upstream or downstream ends of the source line. As shown in the example, RouteZ belongs to Line2. You can take RouteZ from Line2 and transfer it to an existing adjoining line, Line1.
Diagram of existing routes before transfer Diagram of routes after reassignment
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line2
1/1/2005
<Null>
100
Method
Transfer to another line
Source
From Route
RouteZ
From Measure
50
To Route
RouteZ
To Measure
60
Target
Line Name
Line1
Route
RouteZ
From Measure
50
To Measure
60
The original RouteZ is retired on the date of reassignment. RouteZ is recreated on Line1 with the date of reassignment as its start date, and the line order is updated.
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line2
1/1/2005
1/1/2010
100
RouteZ
Line1
1/1/2010
<Null>
300
  • Multiple adjoining routes from a line can be transferred to an adjoining line.
  • Line orders of the existing routes in the target line may be recalculated as a result.
  • If the source routes are transferred to another line in entirety, the original route names and route IDs, as well as their measurements, can be preserved. Alternatively, you can provide a new route name and start and end measures for the transferred routes.
  • If a portion of the source routes are transferred to another line, the original route names cannot be preserved, and a new route name must be selected for the transferred route.
Route transfers to a new line
Routes can be transferred entirely or partially to a new line. As shown in the example, RouteZ belongs to Line1. You can transfer it to a new line, Line2.
Diagram depicting routes before transfer to a new line Diagram depicting routes after transfer to a new line
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line1
1/1/2005
<Null>
300
Method
Source
From Route
RouteZ
From Measure
50
To Route
RouteZ
To Measure
60
Target
Line Name
Line2
Route
RouteZ
From Measure
50
To Measure
60
The original RouteZ is retired on the date of reassignment. RouteZ is recreated on Line2 with the date of reassignment as its starting date value, and the line order is updated.
Route Name
Line Name
From Date
To Date
Line Order
RouteX
Line1
1/1/2005
<Null>
100
RouteY
Line1
1/1/2005
<Null>
200
RouteZ
Line1
1/1/2005
1/1/2010
300
RouteZ
Line2
1/1/2010
<Null>
100
  • Multiple adjoining routes from a line can be transferred to a new line.
  • If the source routes are transferred to a new line in entirety, the original route names and route IDs, as well as their measurements, can be preserved. Alternatively, you can provide a new route name, as well as start and end measures for the transferred routes.
  • If a portion of the source routes are transferred to a new line, the original route names cannot be preserved, and a new route name must be provided for the transferred route.
Parameters in the network
The following tables describe the parameter values used in the Reassign Route tool:
For a network that supports lines
Variable
Network
The network that supports lines in which the routes exist.
Effective Date
This is the date when the reassignment has taken place on the ground.
Source: From Route Name
The route where the reassignment starts.
Source: From Measure
The measure on the source route where the reassignment starts; shown by the green point.
Source: To Route Name
The route where the reassignment ends. For example, if the reassignment takes place on a single route, the source route and target route are the same. The source routes should belong to the same line.
Source: To Measure
The measure on the source route where the reassignment ends, shown by the red point.
Target: Route Name
The route to which the reassigned portion will be added. This can also be a new route.
Target: From Measure
The start measure on the reassigned portion.
Target: To Measure
The end measure on the reassigned portion.
For continuous networks
Variable
Network
The network in which the continuous routes exist.
Effective Date
Source: Route Name/ID
Source: To Measure
Target: Route Name/ID
Target: To Measure
Implement the parameters
You can do the following to implement the parameters above using the Reassign Route tool:
  • Merge to adjacent route—Reassign and merge a portion of a route, the entire route, or multiple routes with an adjacent route.
  • Form a new route—Create a new route by merging source routes if multiple routes are selected in the source or by splitting the source route if a portion of a route is selected in the source. You can also rename a route by selecting an entire route and providing a new route name or ID.
  • Transfer to another line—Transfer routes to a new line by providing a new line name, or transfer routes to an adjacent line by providing an existing line name.
