Connect to authentication providers from ArcGIS Pro
ArcGIS Pro supports configuring authentication connections with external authentication providers. If your organization manages user identities with an authentication provider, such as Microsoft Entra ID or Google, you can add an authentication connection to establish a relationship between the provider and ArcGIS Pro.
Authentication connections are OAuth 2.0 based. For connection types that require user sign-in, you are redirected to the provider's login page, where you can provide your credentials and authorize ArcGIS Pro to access resources on your behalf. Once signed in, you can use the authentication connection in various parts of the application, such as cloud storage connections, OGC service connections, and STAC connections.
The following three sections represent the three steps to connect ArcGIS Pro to an authentication provider.
Register ArcGIS Pro with the authentication provider
An IT administrator typically performs the following steps to register ArcGIS Pro with the authentication provider:
Register ArcGIS Pro with the authentication provider.
Retrieve the application (client) ID generated for ArcGIS Pro.
Provide the redirect URI as
arcgis-pro://auth.This step is not required for Google connections or Client Credentials connections.
For detailed instructions, refer to the documentation available through your authentication provider.
Register ArcGIS Pro with Microsoft Entra ID
The following prerequisites must be met to register an application with Entra ID:
Your Microsoft Azure account must have an active subscription with permission to manage applications in Entra ID.
You must have a Microsoft Entra ID tenant.
For more information, see Register an application in Microsoft Entra ID in the Microsoft documentation.
To register ArcGIS Pro with Microsoft Entra ID, complete the following steps:
Register a new application with the following settings:
In the Name box, enter ArcGIS Pro.
For supported account types, choose Single tenant.
For Redirect URI, choose Mobile and desktop applications as the platform and enter the URI: arcgis-pro://auth.
Enable and grant admin consent for the following API permissions:
Azure Storage > user_impersonation
Microsoft Graph > User.Read (This is enabled by default.)
Optionally, in Token Configuration, add the optional claim login_hint to the ID token.
This is recommended for a more streamlined user experience when signing out of a connection.
When registration is complete, note the Application (client) ID, which uniquely identifies ArcGIS Pro in the Microsoft identity platform. You will use this later when adding authentication connections in ArcGIS Pro.
Note the Microsoft Entra ID domain name. You will use this later when adding authentication connections in ArcGIS Pro.
Register ArcGIS Pro with Google
To register ArcGIS Pro with Google, complete the following steps:
For application type, select Desktop app.
When registration is complete, note the client ID, which uniquely identifies ArcGIS Pro in the Google Auth Platform. You will use this later when adding authentication connections in ArcGIS Pro.
Note the client secret. You will use this later when adding authentication connections in ArcGIS Pro.
For more information, see Manage OAuth Clients in the Google documentation.
Add an authentication connection
To add an authentication connection, complete the following steps:
Open the ArcGIS Pro settings page in one of the following ways:
From an open project, click the Project tab on the ribbon.
From the start page, click the Settings tab
In the list of side tabs, click Authentication.
On the Authentication page, under Add Connections, click Add on the card of your choice.
The following connection types are available:
Microsoft Entra ID
Google
Custom
Client Credentials
Use the Microsoft OneDrive card if you want to sign into a OneDrive connection. Signing in prevents simultaneous editing conflicts when modifying certain types of OneDrive files. For more information, see Connect to Microsoft OneDrive.
On the Add Connection dialog box, type a name for the connection.
Connection names are limited to 50 characters and cannot be changed after the connection is added.
Provide the connection properties and click OK. For a Client Credentials connection, click Connect instead.
Different properties may be required depending on your connection type:
If your connection type is Microsoft Entra ID, provide the Microsoft Entra domain, client ID, and at least one scope. The default is
https://storage.azure.com/.default.If your connection type is Google, provide the client ID and client secret. Optionally, specify a port number where the application will receive authentication responses; the default is 8088. At least one scope is required; the default is
https://www.googleapis.com/auth/devstorage.read_write.If your connection type is Custom, provide the authorization URL, token URL, and client ID from your authentication provider. Optionally, provide scopes and additional request parameters to customize the authentication request.
If your connection type is Client Credentials, provide the token URL, client ID, and client secret. Optionally, provide scopes and additional request parameters to customize the authentication request.
Sign in to an authentication connection
These steps apply to connection types that require user sign-in. The Sign in option does not appear for Client Credentials connections.
Click the Options button
or right-click the connection and click Sign in.You are redirected to a browser.
Provide the credentials associated with your account and click Next.
Follow the prompts from the provider and grant the necessary application permissions if requested.
Depending on how your Microsoft Entra organization is configured, you may see a message indicating that admin approval is required. Contact your administrator to grant ArcGIS Pro the necessary permissions.
If the login is successful, a prompt to open ArcGIS Pro may appear. You can also manually navigate to ArcGIS Pro.
Your organization’s security policies and the authentication provider determine how long you remain signed in. If prompted, sign in again to continue using the connection in ArcGIS Pro.
Manage authentication connections
To manage an authentication connection, click the Options button
or right-click the connection to do the following:
Click Refresh to update the status of the connection. Alternatively, click Refresh
to update the status of all the connections.Click Sign out to sign out of a connection. This option does not appear for Client Credentials connections.
Click Edit to edit the properties of the connection, except the connection name and type.
When you finish editing the connection, click OK or Connect to save the changes. If the connection type is not Client Credentials, you will need to sign in again.
Click Remove to remove a connection.
Administer authentication connections
System administrators who manage application settings may set default authentication connections in your ArcGIS Pro deployment. An administrator can lock connections to prevent them from being changed. A message appears below the connections on the Authentication page if there are any connections managed by an administrator.
The Google and Client Credentials connection types cannot be set by system administrators.
