Connect to Microsoft OneDrive
If your organization uses Microsoft OneDrive and Microsoft SharePoint to store files, an administrator can enable protected access for Microsoft OneDrive files through application settings. You can then connect to a Microsoft work or school account linked to OneDrive on your computer to help prevent simultaneous changes to protected files in ArcGIS Pro. When you're signed in, OneDrive files are checked out to you, allowing you to exclusively modify them. Others are prevented from making changes until the files are checked in.
For more information, see Use ArcGIS Pro with Microsoft OneDrive and Microsoft SharePoint.
Requirements
To add a OneDrive connection, the following are required:
  • Protected access for Microsoft OneDrive files in ArcGIS Pro must be enabled by your administrator through application settings.
  • Your Microsoft work or school account must be linked to Microsoft OneDrive and syncing on your computer. Personal accounts are not supported.
  • Your Microsoft organization must be hosted in the Microsoft commercial cloud. Other national clouds are not supported.
Add and sign in to a OneDrive connection
To add a OneDrive connection and sign in, complete the following steps:
  1. Open the ArcGIS Pro settings page in one of the following ways:
    • From an open project, click the Project tab on the ribbon.
    • From the start page, click the Settings tab .
  2. In the list of side tabs, click Authentication.
  3. On the Authentication page, under Add Connections, click the Add button on the Microsoft OneDrive card.
    If the Microsoft OneDrive card is not present, your administrator has not enabled protected access for your ArcGIS Pro deployment.
  4. On the OneDrive Sign In dialog box that appears, select the desired account.
    Only Microsoft OneDrive work or school accounts are supported; personal accounts do not appear. If the desired account is not listed, a connection may already exist, or you may need to add the account to your computer, restart ArcGIS Pro, and try again.
  5. Click OK.
    You are redirected to a browser.
  6. Provide the credentials associated with your account and click Sign in.
    Depending on how your Microsoft Entra organization is configured, you may see a message indicating that administrator approval is required. Contact your IT administrator to grant ArcGIS Pro the necessary permissions.
    If the login is successful, the browser may prompt you to return to ArcGIS Pro. You can also return to ArcGIS Pro manually and verify that a Microsoft OneDrive connection is added under Connections on the Authentication page.
    Your organization’s security policies determine how long you remain signed in. If prompted, sign in again to continue accessing OneDrive files in ArcGIS Pro.
Manage OneDrive connections
Under Connections, click the Options button or right-click the connection to do any of the following:
  • Click Refresh to update the status of the connection. Alternatively, click Refresh to update the status of all the connections.
  • Click Sign out to sign out of a connection.
  • Click Remove to remove a connection.
