Enable protected access for Microsoft OneDrive files
As an administrator, you can enable protected access for Microsoft OneDrive files through application settings when deploying ArcGIS Pro across your organization. This capability helps maintain data integrity by preventing simultaneous changes to protected files stored in Microsoft OneDrive or Microsoft SharePoint, reducing the risk of conflicts and data corruption. When a signed in user accesses a protected file, ArcGIS Pro checks it out to that user so that others cannot modify it until it is checked in.
Protected access must be enabled on each computer where users work with these files.
It is supported for Microsoft work or school accounts in organizations hosted in the Microsoft commercial cloud. Personal accounts and organizations hosted in other national clouds are not supported.
For more information, see Use ArcGIS Pro with Microsoft OneDrive and Microsoft SharePoint.
Follow these steps to enable protected access through ArcGIS Pro application settings:
  1. If necessary, create a Pro.settingsConfig file and configure user machines to use it.
  2. Open the file in your preferred text editor.
  3. Under Authentication settings, add the OptInOneDrive setting with the value set to true.
    If you created the Pro.settingsConfig file from a template, this setting may already be present. If so, you may need to uncomment it.
    An example of this setting is shown below.
    <Authentication>
      <OptInOneDrive isLocked="true">true</OptInOneDrive>
    </Authentication>
The Microsoft OneDrive card now appears on the Authentication page in the ArcGIS Pro settings, where users can add a OneDrive connection. Additionally, the OneDrive node appears in the Catalog pane, the Contents pane of catalog views, and on browse dialog boxes.
Considerations and limitations
The following are some considerations to be aware of:
  • Protected access is available only on ArcGIS Pro 3.8 and later versions. Before enabling it, ensure that all users in your organization who share projects and data stored on OneDrive can use the same version of ArcGIS Pro with protected access enabled on each computer. If users cannot use the same version, they should not share this content through OneDrive. Using different versions may leave some files unprotected, which can result in simultaneous editing conflicts and data corruption.
  • Depending upon your Microsoft Entra configuration, users may be prompted for administrator approval when signing in to a OneDrive connection. An IT administrator may need to grant ArcGIS Pro the necessary permissions before users can connect.
  • An internet connection is required to sign in to a OneDrive connection and modify protected files in ArcGIS Pro. Users cannot modify files while offline.
  • Disabling protected access removes any existing OneDrive connections from ArcGIS Pro. Users can then modify OneDrive files without protected access, increasing the risk of simultaneous changes.
For additional limitations and cautions, see Use ArcGIS Pro with Microsoft OneDrive and Microsoft SharePoint.
