Preview data
When exploring a collection of items, you can visualize an item's data in the details panel of a catalog view. This can help you decide whether to add the item to a map, analyze it with a geoprocessing tool, edit its geometry or attributes, or work with it in some other way.
Preview an item's spatial data
In a catalog view, you explore spatial data on the Geography tab of the details panel.
Maps are displayed as authored. If they have a basemap layer, the basemap layer specified by the map appears in the preview. For spatial datasets, the Light Gray Canvas basemap is displayed under the data to provide context. You can turn off or change the basemap as appropriate.
Maps or layers created in another application are converted to the ArcGIS Pro format before they are displayed.
To preview the spatial data of an item, complete the following steps:
  1. In a catalog view, click an item containing spatial data, such as a feature class or map.
  2. If necessary, show the details panel.
  3. In the details panel, click the Geography tab.
    The item's spatial data is displayed. A Preview tab and a Manage tab also appear on the ribbon.
  4. Hover over the details panel and use the mouse buttons and wheel to pan, zoom, tilt, or rotate the data as appropriate. Click a feature to identify it in the Pop-up pane.
    Alternatively, click the Preview tab on the ribbon and use the commands in the Navigate group to explore the geography preview.
  5. Optionally, on the ribbon, click the Preview tab. In the Preview group, click Basemap and choose a different basemap.
    Tip:
    You can create a thumbnail image of the data from the geography preview to help you identify it quickly in other contexts. Thumbnails appear in item metadata. They also appear when you browse or search for data in the Catalog pane if you show detailed item pop-ups.
Preview an item's tabular data
In a catalog view, you explore tabular data on the Table tab of the details panel.
To preview the tabular data of an item, complete the following steps:
  1. In a catalog view, click an item containing tabular data, such as a feature class or a text file.
  3. In the details panel, click the Table tab.
    The item's tabular data is displayed.
  4. Explore the item's tabular data.
    1. Right-click a column header and click Sort Ascending or Sort Descending to sort records. Click Custom Sort to sort on multiple columns.
    2. Click the row number of a record to select the record. Press the Ctrl key while clicking to select additional records.
    3. At the bottom of the table, click Show Selected Records to view only selected records. Click Show All Records to view all records.
