Search the project
You can search a project for items stored in the project file, such as maps and layouts, and for items available through connections that you add to the project. Items appear in search results if the item is indexed by ArcGIS Pro and the search term appears in the item's name or item description metadata. If a search result is a container of other items, you can browse into it. For example, you can browse into a file geodatabase or a folder to access its contents.
To search the contents of a project, access the search box in one of the following ways and enter a keyword or keywords:
In the Catalog pane, click the Project tab.
In a catalog view, click Project
in the Contents paneOn a browse dialog box, click Project
in the navigation panel.
In a catalog view or browse dialog box, you can also search the contents of an item container. For example, you can search for items stored in project databases
or folders
The number of search results is reported at the top of the Catalog pane and at the bottom of a catalog view. If there are more than 100 results, links to more results appear at the bottom of the pane or view. You can show more results in increments of 100 or you can show all results. (On browse dialog boxes, the links appear but the total number of results is not reported.)
In most cases, searches do not return items that are not used by ArcGIS Pro or that cannot be added to a project. For example, searches do not return Microsoft Word documents or ArcGIS Pro projects. Searches also do not return the contents of style files. To search for style items, such as symbols or color schemes, you must manage the style in a catalog view.
The search box doesn't appear on the Computer or Favorites tabs in the Catalog pane. These locations are not searchable. If they are selected in a catalog view or on a browse dialog box, the search box is disabled. Certain other item containers, such as Locators
, also cannot be searched. To search for portal items, see Search the active portal.
Search an item container
In a catalog view or browse dialog box, you can restrict the search to a specific item container by selecting it. For example, if you select the Toolboxes container
in the Contents pane of a catalog view and perform a search, results are returned only for project toolboxes and their contents.
You can also restrict the search to an item in a container, such as a specific folder or geodatabase.
Search for items that are not in a project
You can search for items that are not available in the current project if you index items not in projects or use a managed index. Items indexed in these ways can be found in a search of any project, including projects started without a template.
Searches made on a selected item container do not return results for items not in the project or managed indexes. Ensure that the search context is set correctly:
In the Catalog pane, select the Project tab.
In a catalog view, select Project
in the Contents pane.On a browse dialog box, select Project
Search by keyword
To search for items, enter a keyword or keywords in the search box. Add more keywords to refine the search. For example, a search for city park returns only items that are indexed on both keywords.
Keyword order does not affect search results. A search for city park returns the same items as a search for park city.
Keywords are not case sensitive. Underscores and hyphens are treated like spaces. For example, a search for flow finds items named flow-direction and flow_direction.
Keywords are stemmed; that is, search results return all items that share the root form of the keyword. For example, if you search for zones, the results will include items that contain the word zone, zones, or zoning.
It is not necessary to use a wildcard character, such as an asterisk (*), to find unspecified characters at the end of a keyword. This functionality is built in to searches. For example, if you search for wind, the results will include items that contain words such as windmill, windstorm, and so on. Wildcards are not supported at the beginning or in the middle of words.
Sort results
The default order of search results puts the most relevant results at the top. Relevance is determined by factors such as whether the keyword is part of the item name or title and how often it appears in the item description.
In the Catalog pane, catalog views, and browse dialog boxes, you can click the Sort button
to change the sort order. In catalog views and browse dialog boxes, you can sort by different item properties depending on your catalog location. For example, in a catalog view, a search of the Databases container
provides different sort options than a search of the Maps container
. In the Catalog pane, sorting is limited to the relevance and name properties. You can return to the relevance sort order at any time.
You can also sort items by doing the following:
In a catalog view or browse dialog box, click a column heading in the search results. Click again to reverse the sort order.
On the ribbon, when a catalog view is active, click the Catalog tab. In the Organize group, click Sort
and choose a sort option.
Filter results
You can refine search results by applying filters. Filters can also be used without a search to limit the display of items.
The following filters are available. They are described in more detail in the following sections.
Date Modified
Item Type
Location
Map Extent
All four filters are available when you search the entire project. This occurs when you search in the Catalog pane with the Project tab selected, or when you search in a catalog view with the Project container
selected in the Contents pane. These filters are also available when you search in a catalog view with the Folders container
or a specific folder selected.
Each filter, except Location, has options. For example, the Item Type filter has options for filtering by maps, layers, data, styles, and other items. Some options can be expanded to show more options. For example, if you filter by item type, you can choose the Maps option to return all the maps in your project (and nothing except maps). Alternatively, you can expand the Maps option and filter on a specific map type, such as scenes.
In a catalog view, the scope of your search is restricted to the selected item container, and the filters change in the following ways:
Different options may be available. For example, the Item Type filter for the Databases container
has many specific options to filter database items.Fewer filters may be available. For example, the Maps container
does not include the Date Modified filter because maps don't store modification dates.Filters are not available for some containers. If one of those containers is selected, the Filter button
does not appear.
Apply and clear filters
To apply a filter, click Filter
next to the search box. In the drop-down list that appears, expand a filter type, and click an option.
You can apply multiple filters. For example, you can filter search results by item type and modification date. However, options within a filter are mutually exclusive. For example, if you filter by item type, you can choose maps or layouts but not both. If an option has additional options, these are also mutually exclusive.
Active filters are displayed by name on chips in the Catalog pane, catalog views, and browse dialog boxes. If there isn't enough space to show the name, the number of additional active filters is shown instead. The filter name or names can be displayed in a drop-down list.
You can change the search results by applying more filters, choosing different filter options, or clearing filters. The list of search results updates automatically. (However, if you apply a map extent filter and subsequently change the map extent, you must refresh the display to update the results.) If you change search terms, active filters stay in place.
To clear a filter, click Filter
and click Clear next to the filter name in the drop-down list that appears. Alternatively, click the close button
on the filter chip. Click Clear filters to remove all active filters.
You can filter search results by their modification date using predefined options, such as Last 30 Days, or a date range that you specify. Items stored in the project file, such as maps and layouts, don't have modification dates. Neither, for example, do items stored in a mobile geodatabase or OGC GeoPackage. Filtering by modification date removes these items from the search results.
Item Type filter
When you search the project, you can filter search results by item types such as maps, layers, data, styles, layouts, and so on. When you search an item container in a catalog view, different item type filter options may be available.
When the Databases container
is selected in a catalog view, you can filter by several unique options. These include database type, such as file geodatabase, mobile geodatabase, or SQLite database; vector dataset type, such as feature, network, or parcel dataset (among many others); or raster dataset type, such as raster, mosaic, or oriented imagery dataset. However, you can't filter for data items such as shapefiles and Excel sheets that are not stored in databases.
When the Maps container
is selected in a catalog view, the item type filter options are the same as in a project search, except that the options to filter by map files (.mapx) and layer files (.lyrx) are not present. That is because file-based items do not appear in the Maps container.
On browse dialog boxes, the Item Type filter is not available because the contents are automatically filtered to show only relevant items. For example, the Add Data dialog box shows only items that can be added to a map or scene. You can further filter the contents using the drop-down list at the bottom of the browse dialog box.
Location filter
You can filter search results by typing a geographic location name or latitude-longitude coordinates expressed in DD, DMS, or DDM. Items are returned if their spatial extent intersects the location. The ArcGIS World Geocoding Service is used to find locations.
When a location filter is applied, search results are commonly limited to spatial datasets such as geodatabase feature classes and shapefiles. Spatial datasets always have a geographic extent that can be read either from the item metadata or from the item properties if metadata does not exist. Items that are not inherently spatial, such as geoprocessing models and .csv files, can be included in the search results if spatial coordinates are added to their metadata. Similarly, items stored in the project file (.aprx)—such as maps, layers, and layouts—are not returned unless spatial coordinates have been added to their metadata.
The Location and Map Extent filters cannot be used together.
Map Extent filter
You can filter search results by the extent of a map or scene in a project. Maps and scenes are available as filters if they are open in the project and have been made active in the current session. (If a map or scene is open but has not been made active, it appears dimmed in the Filter drop-down list.) A map that is currently the active view has a dot next to its name. Multiple views of the same map are numerically distinguished in parentheses—for example, Europe (1/2) and Europe (2/2). On a browse dialog box, only the currently active map or scene can be used as a filter.
The map extent filter has two comparison options: Intersects (the default) and Within. An item intersects the map extent if any part of its spatial boundary overlaps the map extent. An item is within the map extent if its spatial boundary is entirely contained by the map extent.
These extent comparison options do not appear when you filter portal items by map extent. For portal items, intersection is the only option.
As with the location filter, search results are commonly limited to spatial datasets. No other items are returned unless coordinates are added to their metadata.
The Map Extent and Location filters cannot be used together.
Use Boolean operators
You can narrow or widen a search using the Boolean operators AND, OR, and NOT. Boolean operators must be entered in capital letters. The Boolean operators are described in the following table:
Boolean operators
Boolean operator |
Description |
AND |
This operator is used between keywords. Items are returned if they are indexed on all the keywords connected by AND. This operator is usually unnecessary because typing two keywords without AND has the same effect. The search parks AND urban returns items indexed both on the word parks and on the word urban. (The search parks urban returns the same results.) |
OR |
This operator is used between keywords. Items are returned if they are indexed on any of the words connected by OR. The search parks OR urban returns items indexed on the word parks, items indexed on the word urban, and items indexed on both words. |
NOT |
This operator is used before keywords. Items are not returned if they are indexed on a word that follows NOT. The search parks NOT urban returns items indexed on the keyword parks that are not indexed on the keyword urban. |
You can combine operators to add complexity to a search. Use parentheses or repeat the operator to make the logic clear. The following are examples:
The search historic AND (buildings OR districts) returns these items:
Items indexed on the word historic and the word buildings
Items indexed on the word historic and the word districts
The search (historic AND buildings) OR districts returns these items:
Items indexed on the word districts
The search historic NOT buildings NOT districts returns items indexed on the word historic and not indexed on the word buildings and not indexed on the word districts.
Tip:
A hyphen (-) placed before a word (with no space in between) has the same effect as the NOT operator.
Use quotation marks
Use quotation marks to find items that contain an exact phrase. For example, a search for “open water” returns items only if these two words are indexed next to each other and in this order.
Use item fields
Indexes are built from item descriptions. You can limit searches to specific elements of the item description with item field names. The syntax for an item field name search is item field name:keyword. The following table lists item field names and usage examples:
Item field names
Item field name |
Description |
title |
The Title field of the item description. By default, the title matches the item's file name, but it can be changed. The search title:birds returns items with the word birds in the title. (It also returns items with birds in the item name.) |
type |
The data type of an item. This property is set by the software. The search type:"geodatabase feature class" returns geodatabase feature classes. The search type:shapefile returns shapefiles. To get the best results, use quotation marks around the item type if it contains more than one word. Items of a specific data type are also returned if the search keyword specifies the data type without an item field name. For example, a search for shapefile returns shapefiles as well as items indexed on the word shapefile. |
tags |
The Tags field of the item description. The search tags:agriculture returns items only if the word agriculture is a tag. |
snippet |
The Summary field of the item description. The search snippet:boundary returns items only if the word boundary appears in the summary. |
description |
The Description field of the item description. The search description:satellite returns items only if the word satellite appears in the description. |
credits |
The Credits field of the item description. The search credits:Esri returns items only if the name Esri appears in the credits. |
accessinformation |
The Use Limitations field of the item description. The search accessinformation:attribution returns items only if the word attribution appears in the use limitations. |
Manage search results
You can manage search results in the search box by doing the following:
To clear a search, click the Delete button
in the search box.To repeat a recent search, click the search box drop-down arrow and click one of the listed searches.
To clear the search history, click the search box drop-down arrow and click Clear History.
Incomplete search results
When a project is indexed for the first time, or if an indexing operation is ongoing, a message indicates that indexing is in progress. Search results may be incomplete until indexing finishes. If a search does not return expected results—or any results—possible reasons include the following:
The search term may be misspelled.
You may be searching an item container instead of the entire project.
An indexing operation may have failed because of a memory limit or for another reason.
Indexing may be turned off for one or more locations such as local disks, network disks, or enterprise geodatabases.
Differences in search experiences
The Catalog pane, catalog views, and browse dialog boxes provide similar, but not identical, search experiences. Keep the following in mind when performing a search:
Search results can be sorted on more properties in a catalog view or browse dialog box than in the Catalog pane.
A search performed in the Catalog pane includes all items in the project. In a catalog view or browse dialog box, you can search the project or specific item containers.
In a catalog view, if a map is returned as a search result, you can double-click it to see its layers. In the Catalog pane, double-clicking a map that is a search result opens the map.
In the Catalog pane, you can hover over search results to see their item pop-ups. Item pop-ups aren't available in catalog views or browse dialog boxes.
In the Catalog pane and catalog views, the number of search results is shown. On browse dialog boxes, it is not shown.
