Terminology for working with projects
You'll encounter these terms when working with projects in ArcGIS Pro.
Dataset
A dataset is any project item or portal item that can be added to a map. Examples of datasets include feature classes, tables, services that provide access to data, layer packages, and imagery layers. Datasets may be stored online or on the file system.
Data source
A data source is the dataset to which a map layer is connected.
Default geodatabase
Every project has a default geodatabase. By default, when you create a project, a file geodatabase is created as the default geodatabase. However, you can designate another geodatabase to be the default geodatabase.
The geoprocessing environment uses the project's default geodatabase as the default workspace where output items created by geoprocessing operations are stored. If you create map layers from a layer template, the source datasets for the layers are also created in the default geodatabase.
Supported formats for default geodatabases are file geodatabase (.gdb), mobile geodatabase (.geodatabase), and enterprise geodatabase (.sde).
In a portal project, the default geodatabase is not created automatically. The project creator specifies an existing geodatabase or creates one during project configuration. The supported geodatabase format depends on the collaboration type.
Default toolbox
Every project has a default toolbox. By default, when you create a project, a toolbox is created as the default toolbox. However, you can designate another toolbox to be the default toolbox. Models that are created in your project are stored in the default toolbox.
Supported formats for default toolboxes are ArcGIS toolbox (.atbx), legacy toolbox (.tbx), and Python toolbox (.pyt).
In a portal project, the default toolbox is not created automatically. The project creator specifies an existing toolbox or creates one during project configuration. Only ArcGIS toolboxes (.atbx) are supported.
Home folder
Every project has a home folder. By default, this is the folder in which the project file (.aprx) is stored, and in which the project's default geodatabase and toolbox are created. The home folder is also the default storage location for many items that you create in an ArcGIS Pro session, such as database and server connection files, some analysis results, map and layer files, and other exported files.
In a portal project, the home folder does not store the project file by default. The local copy of the portal project is stored in the user's download location. The default geodatabase and default toolbox locations are specified during project configuration.
Layer template
A layer template is a schema-only layer package that is provided in a specific location where ArcGIS Pro looks for layer templates.
Metadata
Information that describes items in ArcGIS is called metadata. Metadata allows you to find items with a search and evaluate which of the items in your search results is the correct one to use. Organizations typically have a standard that determines what level of content must be provided in an item's metadata to document it. ArcGIS Pro supports several formal standards, or metadata styles. At a minimum, good metadata consists of an item description that includes a title, tags, thumbnail, summary, description, credits, use limitations, and an appropriate extent and scale range for working with the data.
Portal item
A portal item is any item that is accessible from the active portal and is available in the Catalog pane, a catalog view, or a browse dialog box. From the Portal tab in the Catalog pane, web maps and web scenes can be added to the project, and feature, tile, and imagery layers can be added to maps in the project.
Portal project
A project that is created, stored, and updated in an ArcGIS Enterprise portal. Portal projects can be configured for use by a person working on one computer, a person working on multiple computers, or many people working in collaboration. They can also be configured by one person for use by others.
Project
ArcGIS Pro projects help you manage a collection of GIS resources, including the maps, layers, tools, and datasets required to complete your work. Projects can reference content in your organization's portal and on the file system; some project items are saved directly within the project file. By default, projects are stored in the Documents\ArcGIS\Projects folder in your user profile.
Project favorites
Project favorites are frequently used items such as folders, databases, toolboxes, and server connections that you can add to a project from the Catalog pane, a catalog view, or a browse dialog box without browsing to the item's location on disk.
There are two types of project favorites: personal favorites and system favorites. Personal favorites are chosen by individual users and are managed in a file stored by default in each user's roaming profile. System favorites are chosen by system administrators. They are managed in a file stored on a network share and are distributed to groups of users through an application setting.
Project item
A project item is an item stored in the project file (.aprx) or an item added to a project as an item connection. Project items include the following:
  • Maps, layouts, reports, and other items stored in the project file.
  • Folders, databases, toolboxes, GIS servers, styles, and other items to which you make a connection in the Catalog pane or a catalog view.
The contents of a project item are not usually considered project items. For example, files or subfolders in a folder connection, or feature classes in a database connection, are not project items. However, these items are indexed by the search index, and in that context they are described as project items.
Project package
A project package is a portable file with the extension .ppkx that contains a complete project, including the project file, referenced data, item connections, toolboxes, geoprocessing history, and attachments.
Project packages contain two .aprx files—one that is 3.x compatible and one that is 2.x compatible. When you open a project package, the project file compatible with your ArcGIS Pro version is used automatically.
You can use project packages to share projects between colleagues in a work group, across departments in an organization, or with other ArcGIS users through ArcGIS Online or ArcGIS Enterprise. You can also package projects to create an archive or snapshot of a particular project in its current state.
Project templates
A project template specifies the contents of a new project. ArcGIS Pro provides a number of default templates. You can also create a custom project template (.aptx) that may include maps and layouts; connections to folders, databases, toolboxes, and servers; and datasets or schema-only data definitions. Templates can provide standard layouts and styles throughout your organization. A project template is a special type of project package. By default, project templates are stored in the Documents\ArcGIS\ProjectTemplates folder in your user profile.
Untitled project
A project created from the Start without a template option for new projects is an untitled project. An untitled project opens with no maps, scenes, or other views. It is stored in a temporary file and is deleted when you finish working unless you decide to save it. Untitled projects can be used to manage files, edit data and metadata, run scripts, explore data, and perform other tasks that do not require saving a project file.
