Supported data types and items
ArcGIS Online and ArcGIS Enterprise portals
ArcGIS Pro supports many items that may be available from the active portal.
Item Create Display (Read) Edit (Write) Notes
3D Tiles layers – 3D object No Yes No 3D Tiles layers – 3D object can be added to a scene. When a web scene is published, the layer is published as a 3D Tiles layer.
3D Tiles layers – Integrated mesh No Yes No 3D Tiles layers – Integrated mesh can be added to a scene. When a web scene is published, the layer is published as a 3D Tiles layer.
3D Tiles packages Yes Yes No The package is downloaded and a layer referencing the package is created in the scene.
Big data file shares No Yes No You cannot add big data file shares directly to a map. Big data file shares are used as input to GeoAnalytics Tools. The analysis results from these tools are added to a map.
Business Analyst report templates Yes (when connected to local data) Yes Yes (when connected to local data) The report template is downloaded and added to the project. During the process, associated files such as feature classes and ArcGIS Statistical Data Collections (.sdcx) can also be downloaded.
CAD drawings No Yes No The .zip file containing the CAD dataset is downloaded and extracted.
Code samples No Yes No The sample is downloaded and extracted. The extracted folder is added to Folders and any toolboxes discovered within the folder are added to Toolboxes . See Work with geoprocessing samples for more details.
Elevation layers Yes Yes No Elevation layers can be added to a map or scene as an elevation source layer. When a web scene is published, local elevation source layers used by the scene are published as an elevation layer.
Feature layers Yes Yes Yes Layers and tables in a feature layer can be accessed. Feature collection layers can be used in the same manner as other feature layers.
Feature layer views No Yes No Layers and tables in a feature layer view can be accessed.
Feed layers No Yes No These layers are created using ArcGIS Velocity.
Gaussian splat layers No Yes No Gaussian splat layers can be added to a scene. When a web scene is published, the layer is published as a Gaussian splat layer.
Geoprocessing packages Yes Yes No The package is downloaded and unpacked. Layers in the package are added to a map if one is active when the package is added to the project.
Geoprocessing samples No Yes No The sample is downloaded and extracted. The extracted folder is added to Folders , and any toolboxes discovered within the folder are added to Toolboxes . See Work with geoprocessing samples for more details.
Group layers – 2D and 3D No Yes No Group layer items allow you to persist the group layers you create in the Map Viewer as their own separate items. This provides a way to organize and access layers that you frequently use together.
Imagery layers Yes Yes No For imagery layers published from a mosaic dataset, images in an imagery layer can also be accessed.
Indoor Positioning Data Service Yes No No Indoor Data Positioning Service can be associated with a web map or mobile map package to enable the maps for indoor positioning.
KML layers No Yes No
Layer files No Yes No The file is downloaded. A copy of the layer is added to a map.
Layer packages Yes Yes No The package is downloaded and unpacked. A copy of the layer is added to a map.
Layout files No Yes No The file is downloaded. A copy of the layout is added to the project.
Locators Yes Yes No The locator is referenced by the project.
Map image layers Yes Yes No Layers in a map image layer can be accessed if access to data is enabled.
Map files No Yes No The file is downloaded. A copy of the map is added to the project.
Map packages Yes Yes No The package is downloaded and unpacked. A copy of the map is added to the project.
Mobile map packages Yes Yes No The package is downloaded and unpacked. A copy of the map is added to the project.
Mobile scene packages Yes Yes No The package is downloaded and unpacked. A copy of the scene is added to the project.
OGC WFS feature layers Yes Yes No
OGC WMS map image layers Yes Yes No
OGC WMTS tile layers No Yes No WMTS tile layers can be added to a map.
Portal projects Yes Yes Yes ArcGIS Pro projects can be created and managed in ArcGIS Enterprise 11.4 and later portals.
Project packages Yes No No The package is downloaded, unpacked, and opened.
Project templates Yes No No The package is downloaded, unpacked, and opened.
Presentation files No Yes No The file is downloaded. A copy of the presentation is added to the project.
Raster function templates No Yes No
Report files No Yes No The file is downloaded. A copy of the report is added to the project.
Route layers Yes Yes No
Rule packages No No No
Scene layers Yes Yes Yes Web scene layers that copy all data can be created if supported data stores are configured:
Scene layer packages Yes Yes No The package is downloaded and a layer referencing the package is created in the scene.
Spatiotemporal layers No Yes No
Spatiotemporal tables No Yes No
Stream layers No Yes No
Styles No Yes No The style file (.stylx) is downloaded and added to the project.
Tables Yes Yes Yes Hosted tables can be created. Individual tables can also be accessed. Feature collection tables can be used in the same manner as other tables.
Task files No Yes No The file is downloaded. A copy of the task is added to the project.
Tile layers Yes Yes Yes Hosted tile layers can be created. Editing tile layers with associated feature layers is supported on ArcGIS Online or ArcGIS Enterprise.
Tile packages Yes Yes No The package is downloaded and a layer referencing the package is created in the map.
Vector tile layers Yes Yes Yes Vector tile layers can be created and edited. Associated feature layers can be published and used to rebuild the vector tile cache.
Vector tile packages Yes Yes No The package is downloaded and a layer referencing the package is created in the map.
Video layers No Yes No A copy of the video layer is added to the project. Available in ArcGIS Enterprise 11.2+; not available in ArcGIS Online.
Voxel layers Yes Yes No
Web link charts Yes Yes Yes Available in ArcGIS Enterprise 12.0 and later; not available in ArcGIS Online.
Web maps Yes Yes Yes A copy of the map is added to the project and linked to the original item. See Save a web map.
Web scenes Yes Yes Yes A copy of the scene is added to the project and linked to the original item. See Save a web scene.
Web styles Yes Yes No
Web tools Yes Yes No
Services
Connections can be created to ArcGIS Server server sites and to Open Geospatial Consortium (OGC) WCS, WFS, WMS, WMTS, and OGC API services.
Connections to ArcGIS Server can be created with user- or publisher-level privileges depending on the URL that is provided and the level of privileges that are allowed for your credentials. Once the connection is established, you can change the connection to have administrator-level privileges, if they are allowed for your credentials.
With ArcGIS Pro, you share web layers using the active portal. If you connect to a server associated with the active portal, you can access the hosted services associated with web layers; however, you will have access to the data only. Information determining how to draw the data on a map is defined in the web layer in the active portal and is not available when you access the service directly.
Additionally, map, feature, image, geocode, and geoprocessing services can also be published to a stand-alone ArcGIS Server server site.
The following information relates to services accessed from an ArcGIS Server, WCS, WFS, WMS, WMTS, and OGC API connection:
ArcGIS feature services Yes Yes Yes Direct editing and querying is supported. Layers and tables in a feature service can also be accessed.
ArcGIS geocoding services Yes Yes No
ArcGIS geoprocessing services Yes Yes No
ArcGIS globe services No No No A scene's ground can leverage elevation data provided by a globe service. Globe services are deprecated at ArcGIS Pro 3.0.
ArcGIS image services Yes Yes No A scene's ground can leverage elevation data provided by appropriate image services. For imagery layers published from a mosaic dataset, images in an imagery layer can also be accessed.
ArcGIS map services Yes Yes No Layers and tables in a map service can also be accessed if access to data is enabled. Dynamic layers in a dynamic map service are only supported when added from a web layer or when opening a web map.
ArcGIS scene services Yes Yes Yes Editing for point, building, and 3D object scene services with associated feature services is supported. See Edit a scene layer with associated feature layer for details.
ArcGIS stream services No Yes No
OGC Web Coverage Service (WCS) No Yes No
OGC Web Feature Service (WFS) No Yes No
OGC Web Map Service (WMS) No Yes No
OGC Web Map Tile Service (WMTS) No Yes No
OGC API Features Service No Yes No
Geodatabase data
ArcGIS Pro supports file geodatabases and enterprise geodatabases. Versioning is supported in an enterprise geodatabase.
ArcGIS Data Reviewer sessions Yes Yes Yes
Geodatabase feature classes Yes Yes Yes
Geodatabase feature datasets Yes Yes No The contents of the feature dataset are added to the map.
Geodatabase geometric networks No Yes No Network classes are available for display only. They cannot be edited, opened, or analyzed.
Geodatabase mosaic datasets Yes Yes Yes See the list of supported sensors.
Geodatabase network datasets Yes Yes Yes You can create a network dataset and edit its properties such as sources, travel mode, costs, restrictions, and directions. You can also edit a network's source features and build the network.
Geodatabase parcel fabrics Yes Yes Yes Parcel fabrics created in ArcGIS Pro can be edited if they're published as web feature layers that reference the registered data source. Add the web feature layer to the map to edit.
Geodatabase raster datasets Yes Yes Yes See the list of supported sensors.
Geodatabase relationship classes Yes Yes Yes Creating a relationship class is supported using geoprocessing tools only. Attributed relationship class tables can be edited.
Geodatabase tables Yes Yes Yes
Geodatabase terrains Yes Yes Yes Creating and editing a terrain is supported using geoprocessing tools only. In enterprise geodatabases, terrain datasets support traditional versioning.
Geodatabase topologies Yes Yes Yes
Geodatabase trace networks Yes Yes Yes Trace networks can be edited in a single-user deployment with a file geodatabase or in an enterprise deployment if they're published as web feature layers that reference the registered data source. Add the web feature layer to the map to edit.
Geodatabase utility networks Yes Yes Yes Utility networks can be edited in a single-user deployment with a file geodatabase or in an enterprise deployment if they're published as web feature layers that reference the registered data source. Add the web feature layer to the map to edit.
Database data
ArcGIS Pro supports a number of databases and data warehouses, as well as SQLite databases and GeoPackage files.
Database feature classes Yes Yes Yes* Spatial tables and views that contain spatial columns are included.
Spatial tables that are not views can be edited if they're published as web feature layers that reference registered data. Add the web feature layer to the map to edit the data.
Views are not supported in SQLite databases or GeoPackage files.
*You can edit feature classes in SQLite and GeoPackage files. For other supported databases, you can publish an editable web feature layer.
Database tables Yes Yes Yes* Nonspatial tables and views that do not contain a spatial column are included.
*You can edit tables in SQLite and GeoPackage files. For other supported databases, you can publish an editable web feature layer that contains at least one feature class and the table.
Data stored in files
ArcGIS Pro supports several types of data that are stored in files.
3D Tiles Archive File (.3tz) No Yes No
3D Tiles Dataset No Yes No A 3D Tiles Dataset is a folder of files and subfolders containing at least one tileset.json file which describes the dataset.
Adobe portable document format (.pdf) Yes Yes Yes Files in .pdf format can be displayed in the Catalog pane, catalog views, and browse dialog boxes. They can be added as layers to maps if they contain spatial reference information.
Apache Parquet files (.parquet) No Yes No
Big Data Connection files (.bdc) No Yes No At ArcGIS Pro 3.0, big data connections were renamed multifile feature connections. Existing big data connection files are supported.
BIM File Workspace (.rvt) No Yes No
Cache datasets (.tiles) Yes Yes No Cache datasets are created with the Extract Package geoprocessing tool. They support publishing web layers.
CAD datasets (.dgn, .dwg, .dxf) No Yes No
dBASE tables (.dbf) Yes Yes Yes
Excel worksheets (.xls, .xlsx) No Yes No
Extracted scene layer packages (.eslpk) Yes Yes No Extracted scene layer packages are created with the Extract Package geoprocessing tool. They support publishing web layers.
Filtered Find Paths Configuration files (.ffpcfg) Yes Yes Yes Filtered Find Paths Configuration files are used in Knowledge Graph investigations.
Function rasters (.afr) Yes Yes Yes
Keyhole Markup Language files (.kml, .kmz) No Yes No
LAS datasets (.las, .lasd, .zlas) Yes Yes Yes LAS datasets are created with the Create LAS Dataset geoprocessing tool.
Load Data Configuration files (.ldcfg) Yes Yes Yes Load Data Configuration files are used in Knowledge Graph investigations.
Motion imagery No Yes No See the list of supported formats that are available with Image Analyst.
Multifile Feature Connections (.mfc) Yes Yes No
Raster datasets Yes Yes Yes See the list of supported sensors.
Raster products No Yes No See the list of supported sensors.
Scene layer packages (.slpk, .spk) Yes Yes No
Shapefiles (.shp) Yes Yes Yes
Text tables (.asc, .csv, .psv, .tab, .tsv, .txt) No Yes No
Tile packages (.tpk, .tpkx) Yes Yes No
TIN datasets Yes Yes Yes
Vector cache datasets (.vtiles) Yes Yes No Vector cache datasets are created with the Extract Package geoprocessing tool. They support publishing web layers.
Vector tile packages (.vtpk) Yes Yes No
VPF datasets (.aft, .pft, .lft, .tft) No Yes No Vector Product Format (VPF) feature classes are accessible on browse dialog boxes and can be added to maps.
Items that can be added to a project
These items created by ArcGIS Pro can be added to an existing project. A copy of the item is added to the project, or the item is referenced by the project.
Item Notes
ArcGIS Cloud Storage Folder connection (.acs) Only raster datasets stored in this location can be used in the project.
ArcGIS Huff Model (.huffmodel)
ArcGIS Segmentation Profile (.sgprofile)
ArcGIS Segmentation Target Group (.sgtargetgroup)
ArcGIS Server connection (.ags)
ArcGIS Statistical Data Collection (.sdcx)
ArcGIS Workflow Manager (Classic) database connection (.jtc)
Data Model Design file (.dmdesign) Used to import and export data model designs in knowledge graph investigations.
Data Reviewer batch job (.rbj)
Data Reviewer workspace connection (.gdb)
Database connection (.sde) Connections to enterprise geodatabases and databases are added to the project.
Document database connection (.dbconn) You can connect to Elasticsearch or OpenSearch.
File geodatabase (.gdb)
File knowledge graph (.knowledgegraph)
GeoPackage (.gpkg)
Geoprocessing package (.gpkx) A tool is added to the project under Geoprocessing History. If the package contains data, a group layer is also added to the current map.
Layer file (.lyrx) A copy of the layer is added to the map.
Layer package (.lpkx) A copy of the layer is added to the map.
Layout file (.pagx) A copy of the layout is added to the project. Copies of maps in the layout file are also added to the project.
Locator (.loc) Locators created with the deprecated Create Address Locator geoprocessing tool cannot be added to ArcGIS Pro 3.0 or later versions.
Map file (.mapx) A copy of the map is added to the project.
Map package (.mpkx) A copy of the map is added to the project.
Mobile geodatabase (.geodatabase) Mobile geodatabases accessed from ArcGIS Pro are only supported for simple feature workflows. You can edit simple features and attributes, and undo and redo your editing operations. You can also edit feature relationships and file attachments. Workflows associated with advanced behavior, such as managing topology or network rules, are not supported.
OGC WCS server connection (.wcs) A copy of the connection is created in the home folder and added to the project.
OGC WFS server connection (.wfs) A copy of the connection is created in the home folder and added to the project.
OGC WMS server connection (.wms) A copy of the connection is created in the home folder and added to the project.
OGC WMTS server connection (.wmts) A copy of the connection is created in the home folder and added to the project.
OGC API server connection (.ogc) A copy of the connection is created in the home folder and added to the project.
OLE DB connection (.odc)
Presentation file (.prsx) A copy of the presentation is added to the project.
Python notebook (.ipynb)
Report files (.rptx) A copy of the report is added to the project. Copies of maps in the report file are also added to the project.
SQLite database (.sqlite)
Styles and mobile styles (.stylx)
Suitability models container (.sam) The suitability models container and the models it contains are added to the project.
Tasks (.esriTasks) A copy of the task item is added to the project.
Toolbox (geodatabase, .atbx, .pyt, .tbx)
Items that can be imported to a project
The original item is converted to the ArcGIS Pro format, and the converted item is added to the project or to a map in the project. A copy of the converted item is added to the project, or the converted item is referenced by the project. There is no link to the original item. These items were not created by ArcGIS Pro.
Item Notes
ArcGIS place files (.dat) Place files from ArcGIS Desktop documents are imported as bookmarks to the active map.
ArcGIS Pro bookmark files (.bkmx) Bookmark files are imported as bookmarks to the active map.
ArcGlobe documents (.3dd) A scene is added to the project. It uses the 3D global view.
ArcMap documents (.mxd) A map for each data frame is added to the project. A layout is also added to the project.
ArcScene documents (.sxd) A scene is added to the project. It uses the 3D local view.
Desktop styles (.style) An ArcGIS Pro style file (.stylx) is created, saved in the project's home folder, and added to the project.
Layer packages (.lpk) A layer is added to a map or scene in the project.
Layer files (.lyr) A layer is added to a map or scene in the project.
Map packages (.mpk) A map is added to the project.
Mobile map packages (.mmpk) A map is added to the project.
Mobile scene packages (.mspk) A scene is added to the project.
Files available in a project
Some files are available in a project to support your work. For example, .xml files may contain metadata describing a series of items from one source.
Item Notes
Extensible markup language (.xml)
  • ArcGIS-format metadata .xml files can be displayed and edited in the catalog view.
  • Display the log files produced when you import maps in the catalog view.
  • .xml files containing geodatabase content are supported as inputs to and outputs from geoprocessing tools.
Rule package (.rpk)
Files supported as inputs or outputs
These files can be used as inputs or outputs to ArcGIS Pro operations or geoprocessing tools. For example, you can import the spatial reference from the appropriate file type (.prj) to a feature class to define its coordinate system. These files are available on the browse dialog box but are not available in the Catalog pane or catalog view.
It isn't practical to maintain a complete list of which file types are inputs or outputs to which tools and operations. For geoprocessing tools, refer to the tool documentation for this information. For other operations, refer to the relevant documentation.
Item Notes
3D Studio (.3ds)
ArcGIS Authorization (.ecp)
ArcGIS Server service definitions (.sd)
ASCII remap (.rmp)
Bitmap (.bmp)
Collada (.dae)
Colormap (.clr)
Compressed archive (.z, .zip)
Calculate field expression (.exp, .cal)
Enhanced metafile (.emf)
ENVI Spectral Library (.sli)
Esri Classifier Definition (.ecd)
Esri Classification Schema (.ecx)
Esri Spectral Library (.esl)
Executable (.exe)
Exploratory analysis tool (.eat) Learn how to use these files to share configurations for exploratory analysis tools between projects and users.
Extensible stylesheet language transformation (.xsl, .xslt)
FDP (.fdp)
Field map file (.fieldmap)
FME Workbench (.fmw) The appropriate extension must be enabled.
GeoJSON (.geojson)
Geoprocessing package (.gpk)
GL Transmission format binary (.glb)
GL Transmission format (.gltf)
GPS exchange format (.gpx)
Graphics interchange format (.gif)
HyperText markup language (.html)
JavaScript object notation (.json)
Joint photographic experts group (.jpeg)
Label expression (.lxp)
Locator package (.gcpk)
Maplex abbreviation dictionary (.dic)
MS-DOS Command (.com)
NetCDF dataset (.nc)
OpenFlight (.flt)
OpenSceneGraph binary (.osgb)
Oriented imagery catalog (.oic)
Point cloud object detection training dataset (.pcotd) Folders that have a name ending with .pcotd are recognized as this type and handled in ArcGIS Pro as if they were a file. They are visible on browse dialog boxes but not in the Catalog pane or catalog views.
Point cloud training dataset (.pctd) Folders that have a name ending with .pctd are recognized as this type and handled in ArcGIS Pro as if they were a file. They are visible on browse dialog boxes but not in the Catalog pane or catalog views.
Portable network graphic (.png)
Python script (.py)
Query expression (.exp)
R script (.r) Learn about using R scripts in ArcGIS Pro.
Random forest classification (.rfm)
Raster function template (.rft.xml)
Raster catalogs Migrate raster catalogs to geodatabase mosaic datasets.
Report template files (.rptt) A file that contains report elements and which is used to create a report.
Scalable vector graphic (.svg)
Service definition (.sd)
SketchUp (.skp)
Spatial Analyst signature (.gsg)
Spatial reference (.prj)
Spatial weights matrix (.swm)
Tile package (.tpk)
Topology rule (.rul)
UAV/UAS Camera (.cam)
Virtual Reality Modeling Language (.wrl)
Wavefront object (.obj)
Windows batch (.batj)
World (.wld)
World 3D (.wld3)
