Configure a 3D tiles layer
Before you share a 3D tiles layer, you can configure the temporary cache location.
To modify the default configuration of a 3D tiles layer, complete the steps below. To begin the sharing process, set general properties, and finish sharing, see Share a 3D tiles layer.
You can also configure a 3D tiles layer when you configure a web scene. The information in this topic applies in that situation also.
Open the Share As Web Layer pane, and on the General tab, confirm that the layer type is 3D Tiles.
Click the Configuration tab.
The 3D tiles layer is always cached locally.
Accept the default Temp cache location value, which is determined by your share and download options settings, or browse to a different location.
