Share a 3D tiles layer
With ArcGIS Pro, you can share 3D tiles layers from a scene to ArcGIS Online and ArcGIS Enterprise 11.4 or later. As with web scene layers, you can use 3D tiles layers to visualize large quantities of 3D geospatial data in a realistic way.
The following 3D tiles layer types can be shared from ArcGIS Pro:
  • 3D object 3D object tiles layer
  • Integrated mesh Integrated mesh tiles layer
Learn more about 3D tiles layers
To share a 3D tiles layer, you must have the following:
  • An account that is part of an ArcGIS organization with the privilege to create content
  • An account with privileges to publish hosted tile layers
  • A portal configured with an ArcGIS Data Store object store if you are sharing to ArcGIS Enterprise 11.4 or later
To share a 3D tiles layer that references registered data, see Publish a 3D tiles layer from a cache dataset.
You can continue to work with ArcGIS Pro while your sharing job is processing. You can also close ArcGIS Pro. You can monitor the status of your sharing job in the Job Status pane.
Share a 3D tiles layer using the default configuration
To share a 3D tiles layer with the default settings, complete the steps below. To change the default configuration, see Configure a 3D tiles layer.
This short video offers a quick overview of the workflow.
This video was created with ArcGIS Pro 3.4.
  1. Open a scene.
  2. Select the 3D tiles layer from the 3D Layers category of the Contents pane, right-click the selected layer, point to the Sharing menu, and click Share As Web Layer .
    The Share As Web Layer pane appears.
  3. Provide a name for the web layer.
    The default name is the name of the layer.
  4. Optionally, complete the Summary and Tags fields.
    You can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
  5. Optionally, use the Categories drop-down menu to assign content categories.
    You can assign a maximum of 20 categories.
  6. Under Location, use the Portal Folder menu to choose a folder in your portal content to store the web layer. Optionally, create a folder.
    By default, the web layer is stored at the root level of your portal content.
    Tip:
    Click the Browse button to browse to a folder in your portal content. You can also type a folder name in the text box.
  7. Under Sharing Level, specify how the web layer will be shared:
    • Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
    • Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
    • Everyone (public)—Share your content with the public. Anyone can access and see it.
    1. Optionally, under Groups, select groups to which you belong to share your content with their members.
  8. Under Finish Sharing, click Analyze to review for potential problems.
    Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors must be resolved before you can share your GIS resource. Resolving warnings is recommended but not required.
    Learn more about analyzing GIS resources
  9. After you resolve errors, and optionally, resolve warnings, click Publish to share the web layer.
  10. Optionally, click Jobs to monitor the job status.
  11. When the web layer is successfully published, click the Manage the web layer link at the bottom of the pane to access the web layer in your portal.
