ArcGIS.Desktop.Mapping Namespace / MapTool Class / HandleDoubleClickAsync Method
A MapViewMouseButtonEventArgs that contains the event data.
Example
    HandleDoubleClickAsync Method (MapTool)
    Occurs when the OnToolDoubleClick event is handled.
    Syntax
    Protected Overridable Function HandleDoubleClickAsync( _
       ByVal args As MapViewMouseButtonEventArgs _
    ) As Task
    protected virtual Task HandleDoubleClickAsync(
       MapViewMouseButtonEventArgs args
    Parameters
    args
    Return Value
    A Task that represents a mouse double click event.
    Remarks
    This method is intended to perform asynchronous operations associated with a double-click event. It will be called if you override the OnToolDoubleClick virtual method and set the handled property on the MapViewMouseButtonEventArgs to true.
    Example
    Translates a point in map coordinates to a point in page coordinates
      //Note: Must be on QueuedTask.Run
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
      //Convert the clicked point in client coordinates to the corresponding map coordinates.
      //clicked point can be from a Map Tool's HandleMouseDownAsync callback.
      //MapViewMouseButtonEventArgs ClientPoint property.
      Point clickedPoint;
      var clickedMapPoint = MapView.Active.ClientToMap(clickedPoint);
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",
          mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
      //Get the corresponding layout point
      var pointOnLayoutFrame = mapFrame.MapToPage(mapPoint);
      //Create a point graphic on the Layout.
      var cimGraphicElement = new CIMPointGraphic
        Location = pointOnLayoutFrame,
        Symbol = pointSymbol.MakeSymbolReference()
      //Or use GraphicFactory
      var cimGraphicElement2 = GraphicFactory.Instance.CreateSimpleGraphic(
              pointOnLayoutFrame, pointSymbol);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement2);
    Requirements
