Protected Overridable Sub OnToolMouseUp( _ ByVal args As MapViewMouseButtonEventArgs _ )
protected virtual void OnToolMouseUp( MapViewMouseButtonEventArgs args )
Parameters
- args
- A MapViewMouseButtonEventArgs that contains the event data.
//Note: Must be on QueuedTask.Run
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
//Convert the clicked point in client coordinates to the corresponding map coordinates.
//clicked point can be from a Map Tool's HandleMouseDownAsync callback.
//MapViewMouseButtonEventArgs ClientPoint property.
Point clickedPoint;
var clickedMapPoint = MapView.Active.ClientToMap(clickedPoint);
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",
mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
//Get the corresponding layout point
var pointOnLayoutFrame = mapFrame.MapToPage(mapPoint);
//Create a point graphic on the Layout.
var cimGraphicElement = new CIMPointGraphic
Location = pointOnLayoutFrame,
Symbol = pointSymbol.MakeSymbolReference()
//Or use GraphicFactory
var cimGraphicElement2 = GraphicFactory.Instance.CreateSimpleGraphic(
pointOnLayoutFrame, pointSymbol);
ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement);
ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement2);
