ArcGIS.Desktop.Mapping Namespace / MapTool Class / ContextToolbarID Property
Example
    ContextToolbarID Property (MapTool)
    Gets or sets the DAML ID of the toolbar to display for the tool.
    Syntax
    Protected Property ContextToolbarID As String
    protected string ContextToolbarID {get; set;}
    Example
    Set a MiniToolbar, ContextMenuID
    // daml entries
    // <menus>
    //  <menu id="MyMenu" caption="Nav">
    //    <button refID="esri_mapping_prevExtentButton"/>
    //    <button refID="esri_mapping_fixedZoomInButton"/>
    //  </menu>
    // </menus>
    // <miniToolbars>
    //   <miniToolbar id="MyMiniToolbar">
    //    <row>
    //    </row>
    //   </miniToolbar>
    // </miniToolbars>
    /// <summary>
    /// Represents a map sketch tool that provides a custom context menu and mini toolbar for user interactions.
    /// </summary>
    /// <remarks>This tool enables line sketching on the map and displays a context menu and mini toolbar, as
    /// specified by their respective DAML IDs, when activated. The context menu and toolbar can be customized to include
    /// commands relevant to the sketch workflow. The tool is configured to output line geometry directly to the map.
    /// <para> The <see cref="MapTool.ContextMenuID"/> and <see cref="MapTool.ContextToolbarID"/> properties are set to
    /// reference custom DAML menu and mini toolbar definitions. Ensure that the specified IDs correspond to valid DAML
    /// entries in your add-in configuration. </para></remarks>
    public class SketchToolWithToolbar : MapTool
      public SketchToolWithToolbar()
        IsSketchTool = true;
        SketchType = SketchGeometryType.Line;
        SketchOutputMode = SketchOutputMode.Map;
        ContextMenuID = "MyMenu";
        ContextToolbarID = "MyMiniToolbar";
    Requirements
