ArcGIS.Desktop.Mapping Namespace / MapTool Class / OverlayControlID Property
Example
    Gets or sets the DAML ID of the embeddable control to show on the map view when the tool is active.
    Syntax
    Protected Property OverlayControlID As String
    protected string OverlayControlID {get; set;}
    Remarks
    In some cases you may need to provide a control that displays on top of the map view to configure the behavior of the tool while in use similar to the measure tool. This property allows you to define a Embeddable Control to display on top of the map view while to the tool is active. When you activate a different tool the overlay control will be removed. You can get a reference to the Embeddable Control using the OverlayEmbeddableControl property.
    Example
    How to position an embeddable control inside a MapView
    public ProSnippetMapTool()
      //Set the MapTool base class' OverlayControlID to the DAML id of your embeddable control in the constructor
      OverlayControlID = "ProAppModule1_EmbeddableControl1";
    // Override the MapTool base class' OverlayControlPositionRatio property to set the position of the embeddable control
    protected static void OnToolMouseDown(MapViewMouseButtonEventArgs e)
      if (e.ChangedButton == MouseButton.Left)
        e.Handled = true;
    // Override the MapTool base class' HandleMouseDownAsync method to set the position of the embeddable control
    protected static Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
      return QueuedTask.Run(() =>
        Point
              //assign the screen coordinate clicked point to the MapTool base class' OverlayControlLocation property.
              OverlayControlPositionRatio = e.ClientPoint;
    Tool with an Overlay Embeddable Control
    // Using the Visual Studio SDK templates, add a MapTool and an EmbeddableControl
    // The EmbeddableControl is registered in the "esri_embeddableControls" category in the config.daml file
    //  <categories>
    //    <updateCategory refID = "esri_embeddableControls" >
    //      <insertComponent id="mapTool_EmbeddableControl" className="EmbeddableControl1ViewModel">
    //        <content className = "EmbeddableControl1View" />
    //      </insertComponent>
    //    <updateCategory>
    //  </categories>
    internal class MapTool_WithOverlayControl : MapTool
      public MapTool_WithOverlayControl()
        // substitute this string with the daml ID of the embeddable control you added
        OverlayControlID = "mapTool_EmbeddableControl";
      protected override void OnToolMouseDown(MapViewMouseButtonEventArgs e)
        e.Handled = true;
      protected override Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
        //Get the instance of the ViewModel
        var vm = OverlayEmbeddableControl;
        if (vm == null)
          return Task.FromResult(0);
        // cast vm to your viewModel in order to access your properties
        //Get the map coordinates from the click point and set the property on the ViewMode.
          var mapPoint = MapView.Active.ClientToMap(e.ClientPoint);
          string clickText = string.Format("X: {0}, Y: {1}, Z: {2}", mapPoint.X, mapPoint.Y, mapPoint.Z);
    Requirements
