ArcGIS.Desktop.Mapping Namespace / MapTool Class / SketchSymbol Property
Example
    SketchSymbol Property (MapTool)
    Gets or sets the symbol to use for the sketch. This is only supported when creating a sketch in map coordinates.
    Syntax
    Protected Property SketchSymbol As CIMSymbolReference
    protected CIMSymbolReference SketchSymbol {get; set;}
    Example
    Change symbol for a sketch tool
    internal class SketchTool_WithSymbol : MapTool
      public SketchTool_WithSymbol()
        IsSketchTool = true;
        SketchOutputMode = SketchOutputMode.Map; //Changing the Sketch Symbol is only supported with map sketches.
        SketchType = SketchGeometryType.Rectangle;
      protected override Task OnToolActivateAsync(bool hasMapViewChanged)
        return QueuedTask.Run(() =>
          //Set the Sketch Symbol if it hasn't already been set.
          if (SketchSymbol != null)
            return;
          var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.CreateRGBColor(24, 69, 59),
                              SimpleFillStyle.Solid,
                            SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Dash));
          SketchSymbol = polygonSymbol.MakeSymbolReference();
    Requirements
