Gets or sets if the sketch needs a selection in order to operate. This requirement allows the tool to have two different modes; the normal sketch mode and an additional selection mode.The user is able to toggle the tool between sketch and select modes by pressing and holding down the SHIFT key. When this occurs the sketch is suspended and the user can select additional features. Releasing the SHIFT key puts the tool back into sketch mode, restores the previous state of the sketch (and the sketch undo / redo stack) and allows you to resume sketching.
The default value is false.
