ArcGIS.Desktop.Framework Namespace / DockPaneManager Class
Members Example
    This class manages the active ArcGIS.Desktop.Framework.Contracts.DockPane instances and supplies the mechanism for instantiating new dock panes.
    Object Model
    DockPaneManager ClassDockPane Class
    Syntax
    Public NotInheritable Class DockPaneManager
    public sealed class DockPaneManager
    Example
    Find a dockpane
    // in order to find a dockpane you need to know its DAML id
    var pane = FrameworkApplication.DockPaneManager.Find(dockPaneID);
    Dockpane operations
      // determine visibility
      bool visible = pane.IsVisible;
      // activate it
      pane.Activate();
      // determine dockpane state
      DockPaneState state = pane.DockState;
      // pin it
      pane.Pin();
      // hide it
      pane.Hide();
    Dockpane undo / redo
      // get the undo stack
      OperationManager manager = pane.OperationManager;
      if (manager != null)
        // undo an operation
        // Use await with UndoAsync and RedoAsync
        if (manager.CanUndo)
          manager.UndoAsync().Wait();
        // redo an operation
        if (manager.CanRedo)
          manager.RedoAsync().Wait();
        // clear the undo and redo stack of operations of a particular category
        manager.ClearUndoCategory("Some category");
        manager.ClearRedoCategory("Some category");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.DockPaneManager
    Requirements
