ArcGIS.Desktop.Core.Geoprocessing Namespace / IGPHistoryItem Interface / TimeStamp Property
Example
    TimeStamp Property (IGPHistoryItem)
    Creation time
    Syntax
    ReadOnly Property TimeStamp As Date
    DateTime TimeStamp {get;}
    Example
    How to access Geoprocessing History
      string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
      Project.OpenAsync(openProjectPath);
      MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
      // Note: Needs QueuedTask to run
      var map = mapProjItem.GetMap();
      var ftrLayer = map.Layers[0] as FeatureLayer;
      string tool1 = "management.GetCount";
      var args1 = Geoprocessing.MakeValueArray(ftrLayer);
      var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
      var t = Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
      IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
      string hitemID = "";
      string hitemToolPath = "";
      IGPResult hitemGPResult = null;
      DateTime hitemTimeStamp;
      foreach (var hitem in hisItems)
        // common IGPHistoryItem and Item properties
        hitemID = (hitem as Item).ID;
        hitemToolPath = hitem.ToolPath;
        hitemGPResult = hitem.GPResult;
        hitemTimeStamp = hitem.TimeStamp;
        // use the properties as needed
    Requirements
    ArcGIS Pro version: 3.1 or higher.
