ArcGIS.Desktop.Framework.Contracts Namespace / BackstageTab Class
Members Example
    BackstageTab Class
    Represents a tab in the application backstage. This is an abstract class.
    Syntax
    Public MustInherit Class BackstageTab
       Inherits PropertyChangedBase
       Implements System.ComponentModel.INotifyPropertyChanged
    Remarks
    The Backstage is a full-screen user interface view that exposes additional functionality for the application and current project. The backstage consists of tabs and buttons. Each tab is scoped to a particular task and presents its own user interface. Buttons are simply commands that perform an operation and have no additional user interface in the backstage.
    Backstage tabs are also contextual and will appear disabled if they specify a condition that has not been satisfied.
    A custom BackstageTab has two components: a component class that derives from BackstageTab and a view class that derives from System.Windows.FrameworkElement, typically a System.Windows.Controls.UserControl. Backstage tabs must be defined in DAML.
    DAML attributes
    id Required identifier.
    caption The tab label.
    keytip The access key for the tab in keytip mode.
    condition The DAML condition ID if the tab is contextual.
    separator Show a separator before the item.
    className Required class identifier. Optionally include namespace if not in default namespace.
    assembly Assembly name if not in the default assembly.
    publicKeyToken The necessary public key token if the assembly is strongly named.
    version The version of the dll if the assembly is strongly named.
    Example
    <backstage>
       <insertTab id=acme_backstage_Options keytip="D" className="AcmeBackstageVM" caption="Options>
        <content className="AcmeBackstageTabOptionsView"/>
      </insertTab>
    </backstage>
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Framework.Contracts.BackstageTab
    Requirements
