ArcGIS.Desktop.Framework.Contracts Namespace / ConfigurationManager Class / OnCanExecuteCommand Method
The DAML ID of the command about to execute.
The command's parent module DAML ID.
    OnCanExecuteCommand Method (ConfigurationManager)
    Gives a configuration the ability to disable commands.
    Syntax
    Protected Friend Overridable Function OnCanExecuteCommand( _
       ByVal cmdID As String, _
       ByVal moduleID As String _
    ) As Boolean
    protected internal virtual bool OnCanExecuteCommand(
       string cmdID,
       string moduleID
    Parameters
    cmdID
    moduleID
    Requirements
