ArcGIS.Desktop.Framework.Contracts Namespace / DockPane Class / OperationManager Property
Example
    OperationManager Property (DockPane)
    Gets the OperationManager associated with the DockPane.
    Syntax
    Public Overridable ReadOnly Property OperationManager As OperationManager
    public virtual OperationManager OperationManager {get;}
    Remarks
    Each Pane and DockPane instance by default has their own OperationManager which represents an operation stack. The application's undo/redo controls work with the current OperationManager which is established by the active window. When a Pane or DockPane is activated, its OperationManager is requested. Derived classes can use this method to provide their own OperationManager. For example, Map Panes representing a specific Map, all share the same OperationManager.
    Example
    Dockpane undo / redo
      // in order to find a dockpane you need to know its DAML id
      pane = FrameworkApplication.DockPaneManager.Find(dockPaneID);
      // get the undo stack
      OperationManager manager = pane.OperationManager;
      if (manager != null)
        // undo an operation
        // Use await with UndoAsync and RedoAsync
        if (manager.CanUndo)
          manager.UndoAsync().Wait();
        // redo an operation
        if (manager.CanRedo)
          manager.RedoAsync().Wait();
        // clear the undo and redo stack of operations of a particular category
        manager.ClearUndoCategory("Some category");
        manager.ClearRedoCategory("Some category");
    Requirements
