ArcGIS.Desktop.Framework Namespace / OperationManager Class
Members Example
    A collection of operations that users can undo and redo.
    Object Model
    OperationManager ClassOperation ClassOperation ClassOperation Class
    Syntax
    Public Class OperationManager
    public class OperationManager
    Remarks
    In general, undo operations are organized per ArcGIS.Desktop.Framework.Contracts.Pane and ArcGIS.Desktop.Framework.Contracts.DockPane. In other words, each Pane and DockPane manages its own operation stack. For example, operations added to map A are not visible to map B. The active window (Pane or DockPane) becomes the active OperationManager. When a window becomes active, its OperationManager is requested and connected to the undo/redo user interface.
    Panes and DockPanes may however elect to share OperationManagers. For example, two Panes that are showing the same map will have the same OperationManager.
    Example
    Undo/Redo Edit Operations
    // Executes an edit operation and demonstrates how to undo the operation programmatically.
    await QueuedTask.Run(() =>
      var editOp = new EditOperation
        Name = "My Name"
      if (!editOp.IsEmpty)
        //Execute and ExecuteAsync will return true if the operation was successful and false if not
        var result = editOp.Execute();
        if (result == true)
          // If the operation was successful, you can undo it
          editOp.UndoAsync();
    Undo/Redo the Most Recent Operation
    // Demonstrates how to undo and redo the most recent operation using the map's operation manager.
      //undo
      if (activeMap.OperationManager.CanUndo)
        activeMap.OperationManager?.UndoAsync();//await as needed
      //redo
      if (MapView.Active.Map.OperationManager.CanRedo)
        activeMap.OperationManager?.RedoAsync();//await as needed
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.OperationManager
          ArcGIS.Desktop.Framework.CompositeOperationManager
    Requirements
