Public MustInherit Class Pane Inherits PaneBase Implements ArcGIS.Desktop.Framework.DragDrop.IDropTarget, System.ComponentModel.INotifyPropertyChanged
public abstract class Pane : PaneBase, ArcGIS.Desktop.Framework.DragDrop.IDropTarget, System.ComponentModel.INotifyPropertyChanged
The framework supports multiple panes, letting users display and interact with multiple subjects. Only one pane can be active at a time. The active pane helps establish what is available on the ribbon; switching between different panes may result in changes to the visible tabs. The active pane represents what the user is working with at any given time and therefore provides the primary context for the application. You can open many panes at the same time and these can be grouped or tiled.
Panes can be associated with a default tab and a default tool such that if no other relevant tool/tab is already selected, the default will automatically be selected when the pane is activated.
Panes have two components: a component class that derives from the Pane abstract class and a view class that derives from FrameworkElement, typically a UserControl. Panes must be defined in DAML.
Declaring Panes in DAML: <panes>
<pane id="acme_basicPane" className="BasicPaneViewModel" caption="Basic Pane" isDropTarget="true" loadingMessage="Initializing..."
defaultTab="acme_mainTab" defaultTool="acme_selectTool" smallImage="pack://application:,,,/Acme;component/Images/BasicPane.png" >
<content className="BasicPaneView"/>
</pane>
</panes>
| DAML attributes | |
| id | Required identifier. |
| caption | The default Pane heading. |
| extendedCaption | A more descriptive title. |
| loadingMessage | Temporary message appearing while Pane is initializing. |
| showLoadingMessage | Loading message visibility. |
| isDropTarget | Flag specifying whether the Pane processes drag/drop events directly. Defaults to true. |
| defaultTab | Tab to activate when Pane activates. |
| defaultTool | Tool to activate when Pane activates. |
| defaultDockPane | DockPane to activate when Pane activates. |
| hasCloseAllButThisCommand | Enable or disable the 'Close all but this' command on the Pane's context menu. |
| smallImage | Image appearing in tab header. |
| className | Required class identifier. Optionally include namespace if not in default namespace. |
| assembly | Assembly name if not in the default assembly. |
| publicKeyToken | The necessary public key token if the assembly is strongly named. |
| version | The version of the dll if the assembly is strongly named. |
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Framework.Contracts.PlugIn
ArcGIS.Desktop.Framework.Contracts.PaneBase
ArcGIS.Desktop.Core.ViewStatePane
