ArcGIS.Desktop.Editing Namespace / InspectorProvider Class / SharedFieldColumnSizeID Method
    Gets a unique GUID for any inspector created from this provider. Use this to control the width of the first column (field name or alias) across multiple inspector grids. If multiple inspectors use the same GUID, then the inspector grids for each will appear with shared column widths.
    Syntax
    Public Overridable Function SharedFieldColumnSizeID() As Guid
    public virtual Guid SharedFieldColumnSizeID()
    Remarks
    Normally the inspector grid sizes the first column width (field name or alias) to be as long as needed to show the longest field name in the inspector. If multiple inspectors use the same GUID, then they are coupled together so that the first column width is as long as needed to show the longest field name of the the combined inspectors.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
