ArcGIS.Desktop.Framework.Contracts Namespace / Module Class / OnPaneActivated Method
The Pane being activated.
    OnPaneActivated Method (Module)
    Called by the Framework when a Pane is activated.
    Syntax
    Protected Friend Overridable Sub OnPaneActivated( _
       ByVal incomingPane As Pane _
    protected internal virtual void OnPaneActivated(
       Pane incomingPane
    Parameters
    incomingPane
    Remarks
    Modules are automatically notified whenever one of its panes are activated, deactivated, opened, or closed. This means a Module doesn’t have to listen to the Framework’s ActivePaneChanged event and from here filter for its panes; instead, Modules are given direct notification that one of their panes changed.
    Requirements
