ArcGIS.Desktop.Framework.Contracts Namespace / Module Class / OnPaneClosed Method
The Pane being closed.
    OnPaneClosed Method (Module)
    Called by the Framework when a Pane is closed.
    Syntax
    Protected Friend Overridable Sub OnPaneClosed( _
       ByVal pane As Pane _
    protected internal virtual void OnPaneClosed(
       Pane pane
    Parameters
    pane
    Remarks
    Modules are automatically notified whenever one of its panes are activated, deactivated, opened, or closed. This means a Module doesn’t have to listen to the Framework’s ActivePaneChanged event and from here filter for its panes; instead, Modules are given direct notification that one of their panes changed.
    Requirements
