ArcGIS.Desktop.Framework.Contracts Namespace / Spinner Class
Members
    Spinner Class
    Represents a control that can be used to display and edit doubles. This is an abstract class.
    Syntax
    Public MustInherit Class Spinner
       Inherits PlugIn
       Implements System.ComponentModel.INotifyPropertyChanged
    public abstract class Spinner : PlugIn, System.ComponentModel.INotifyPropertyChanged
    Remarks
    Spinners edit doubles like an edit box except they additionally provide increment and decrement buttons and support a range established with the minimum and maximum attributes. In DAML you can also specify a default value and an increment value. Use the format attribute to specify how to display the double. For example, use 'C' to present a currency or F4 for a double with 4 decimals. In addition, use the suffix attribute to tag on a trailing string such as a '%' sign.
    Spinners do not support delay loading with loadOnClick, they are instantiated when they become visible.
    DAML attributes
    assembly Assembly name if not in the default assembly.
    caption The heading.
    categoryRefID Adds control to a specific component category.
    className Required class identifier. Optionally include namespace if not in default namespace.
    condition Automatically disable the button if the condition is not satisfied.
    defaultValue The initial value.
    disableIfBusy Automatically disable the button if the application is busy. Default true.
    extendedCaption A more descriptive title.
    format The double format string, e.g. 'C' for currency and F4 to show 4 decimal places. Default is F2.
    helpContextID The help topic to show.
    id Required identifier.
    image Image (16x16) used when spinner is middle and large sized.
    increment The amount to add and subtract to the value when the increment and decrement buttons are clicked. Default is 1.0.
    maximum The maximum value.
    minimum The minimum value.
    publicKeyToken The necessary public key token if the assembly is strongly named.
    suffix Trailing string such as '%'.
    version The version of the dll if the assembly is strongly named.
    width The width of the control.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Framework.Contracts.PlugIn
             ArcGIS.Desktop.Framework.Contracts.Spinner
    Requirements
