ArcGIS.Desktop.Mapping Namespace / TableView Class / GetFieldIndex Method
The name of the field.
Example
    GetFieldIndex Method (TableView)
    Gets the index of the field with the given name.
    Syntax
    Public Function GetFieldIndex( _
       ByVal fieldName As String _
    ) As Integer
    public int GetFieldIndex(
       string fieldName
    Parameters
    fieldName
    Return Value
    The index of the field. -1 is returned if the field name is not found.
    Example
    Field Access
      // field access
      var flds = tableView.GetFields();
      var fldIdx = tableView.GetFieldIndex("STATE_NAME");
      var fldDesc = tableView.GetField(fldIdx);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
