ArcGIS.Desktop.Mapping Namespace / TableView Class / GetSelectedRowIndexes Method
Example
    GetSelectedRowIndexes Method (TableView)
    Gets the indexes of all the selected rows. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSelectedRowIndexes() As IReadOnlyList(Of Long)
    public IReadOnlyList<long> GetSelectedRowIndexes()
    Return Value
    A read-only list of row indexes.
    Exceptions
    ExceptionDescription
    Example
    Get selected rows or row indexes
      // Note: Needs QueuedTask to run
        // get the set of selected objectIDs
        var selOids = tableView.GetSelectedObjectIds();
        // get the set of selected row indexes
        var selRows = tableView.GetSelectedRowIndexes();
    Change selected rows
        // set of selected OIDS
        var newoids = new List<long>();
        newoids.AddRange([10, 15, 17]);
        tableView.Select(newoids, true);
        // add to set of selected row indexes
        var newRows = new List<long>(selRows);
        newRows.AddRange([21, 35]);
        tableView.Select(newRows, false);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
