ArcGIS.Desktop.Mapping Namespace / TableView Class / SortAsync Method
The field sort information. When null the sort of the table will revert to database order. If any of the field's sort information is set to FieldSortInfo.AscCase or FieldSortInfo.DescCase, the sort will be case sensitive.
Example
    SortAsync Method (TableView)
    Sorts the attributes in the table view.
    Syntax
    Parameters
    sortFields
    Return Value
    Returns True the sort succeeded.
    Example
    Sort
      // sort the active field descending
      if (tableView.CanSortDescending)
        tableView.SortDescending();
      // sort the active field ascending
      if (tableView.CanSortAscending)
        tableView.SortAscending();
      // perform a custom sort programmatically
      if (tableView.CanCustomSort)
        // sort fields
        Dictionary<string, FieldSortInfo> dict = new()
          { "STATE_NAME", FieldSortInfo.Asc },
          { "CITY_NAME", FieldSortInfo.Desc }
        tableView.SortAsync(dict);
      // perform a custom sort via the UI
        tableView.CustomSort();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
