ArcGIS.Desktop.Layouts Namespace / GraphicElement Class / Clone Method
String
Example
    Clone Method (GraphicElement)
    Generates a cloned copy of an existing GraphicElement on a page layout. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Clone( _
       Optional ByVal suffix As String _
    ) As GraphicElement
    public GraphicElement Clone(
       string suffix
    Parameters
    suffix
    String
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Map has reached maximum graphics count limit of 4000 elements. One or more elements cannot be created.
    Map has reached maximum graphics size limit of 10 MB. One or more elements cannot be created.
    Remarks
    The suffix parameter is an optional string that is used to tag each newly created GraphicElement. The new element will get the same element name as the parent graphic plus the suffix value along with a numeric sequencer. This makes it possible, if needed, to find and remove unwanted cloned items.
    Example
    Clone an element
      //Clone a layout graphic element and apply an offset.
      //Note: Must be on QueuedTask.Run
      // Reference a graphic element by name
      GraphicElement graphicElement =
                          layout.FindElement("MyElement") as GraphicElement;
      if (graphicElement != null)
        //Clone and set the new x,y
        GraphicElement cloneElement = graphicElement.Clone("Clone");
        double xOffset = 0;
        double yOffset = 0;
        cloneElement.SetX(cloneElement.GetX() + xOffset);
        cloneElement.SetY(cloneElement.GetY() + yOffset);
    Requirements
