ArcGIS.Desktop.Layouts Namespace / GraphicElement Class
Members Example
    Represents a graphic element on a page layout.
    Object Model
    GraphicElement ClassGraphicElement ClassCoordinate2D StructureEnvelope ClassCIMElement ClassGeometry ClassCIMGraphic ClassIElementContainer Interface
    Syntax
    Remarks
    Graphic elements are a type of Element and include inserted graphic points, lines, or area shapes. PictureElement and TextElement are also a type of graphic element.
    The Graphic property returns a CIM representation of the graphic specific attributes for a GraphicElement. This may provide additional, finer grained properties exposed in the CIM that are not exposed in the managed API. SetGraphic applies the changes made to a modified CIMGraphic back to the GraphicElement.
    The Clone method allows you to duplicate existing graphic elements on your page layout. This can be useful where you may have a variable number of pictures, for example, on each page in the map series. Rather than authoring a layout with all possibilities, a single picture element can be cloned and updated the appropriate number of times to reference a different set of pictures on disk for each page in the series.
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      await QueuedTask.Run(() =>
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Find layout elements
      //Find elements by name
      var layoutElementsToFind = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
      //Get the collection of elements from the page layout. Nesting within GroupElement is preserved.
      var elementCollection = layout.GetElements();
      //Get the collection of Element from the page layout as a flattened list. Nested groups within GroupElement are not preserved.
      var elements = layout.GetElementsAsFlattenedList();
      //Convert collection of the elements to a collection of GraphicElements.
      var graphicElements = elements.ToList().ConvertAll(x => (GraphicElement)x);
      //Find elements by type
      //Find all point graphics in the Layout
      var pointGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPointGraphic);
      //Find all line graphics in the Graphics Layer
      var lineGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMLineGraphic);
      ////Find all polygon graphics in the Graphics Layer
      var polyGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPolygonGraphic);
      ////Find all text graphics in the Graphics Layer
      var textGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMTextGraphic);
      ////Find all picture graphics in the Graphics Layer
      var pictureGraphic = graphicElements.Where(elem => elem.GetGraphic() is CIMPictureGraphic);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Layouts.Element
             ArcGIS.Desktop.Layouts.GraphicElement
                ArcGIS.Desktop.Layouts.PictureElement
                ArcGIS.Desktop.Layouts.TextElement
    Requirements
