ArcGIS.Core.CIM Namespace / CIMGraphic Class
Members Example
    CIMGraphic Class
    Represents a graphic.
    Object Model
    CIMGraphic ClassCIMSymbolReference Class
    Syntax
    Example
    Create Rectangle Paragraph Text Element 1
      //Note: Must be on QueuedTask.Run
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Set symbology, create and add element to layout
      //Also notice how formatting tags are using within the text string.
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Update an elements transparency
      //Update an element's transparency using the CIM.
      // Reference a element by name
      GraphicElement graphicElement = layout.FindElement("MyElement") as GraphicElement;
      if (graphicElement != null)
        // Modify the Transparency property that exists only in the CIMGraphic class.
        CIMGraphic CIMGraphic = graphicElement.GetGraphic() as CIMGraphic;
        CIMGraphic.Transparency = 50; // mark it 50% transparent
        graphicElement.SetGraphic(CIMGraphic);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGraphic
             ArcGIS.Core.CIM.CIMInkGraphic
             ArcGIS.Core.CIM.CIMPictureGraphic
             ArcGIS.Core.CIM.CIMShapeGraphic
             ArcGIS.Core.CIM.CIMTextGraphicBase
    Requirements
